Oil consumption. Overall concensus??
Old Jan 10, 2013 | 09:19 PM
mrgrey's Avatar
Okay so I have a oil consumption and have read the forums and it appears this issue is pretty common? So now, does anyone have any solutions besides ripping out the motor and rebuilding it?
Old Jan 10, 2013 | 10:31 PM
BowWizzel's Avatar
Other than switching over to conventional oil to see if it will slow or stop it if your using synthetic than I'm 99% sure its a no. Btw what year is yours?
Old Jan 10, 2013 | 11:27 PM
mrgrey's Avatar
2003 6mt coupe, Royal Purple10w30. I am a qt. low and the last oil change was 2000miles ago.
Old Jan 10, 2013 | 11:40 PM
BowWizzel's Avatar
Doesn't sound bad, I'd switch over to conventional if I were you & check back in another 2k miles. Its not worth it to use expensive oil if its just going to eat it up. Whats your mileage?
Old Jan 10, 2013 | 11:49 PM
mrgrey's Avatar
106, my motor is way to high for conventional
Old Jan 11, 2013 | 12:06 AM
BowWizzel's Avatar
How is that? If you switch from regular oil to synthetic at a high mileage it may cause problems but it shouldn't be no problem the other way around. But ya, as I seen it you got 3 options. Try dino oil, keep adding your choice of oil, or short block rebuild if the oil situation is really getting bad.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
