interchangeble engines
Old Jan 11, 2013 | 06:55 PM
Texas-G's Avatar
what engine will fit on my 04 coupe 5AT will a engine of a 06g35 work? any help is appreciated it tried searching no luck, thanks for the info in advance.
Old Jan 11, 2013 | 08:54 PM
Texas-G's Avatar
Anybody? I need to know asap please.
Old Jan 12, 2013 | 06:35 AM
hologram's Avatar
Manual/automatic will determine if revup or not for the 06...on top of that depending how old/new your car is there was a variation in ECU between those engines the one's put in later 04's...so give moar info.
Old Jan 12, 2013 | 08:05 AM
Texas-G's Avatar
My car is a 5at as far as the engine im not sure if it was a 6nt or 5at my car was made in november of 04 I believe not too sure
Old Jan 12, 2013 | 10:36 AM
OBsessed's Avatar
I believe you can use the short block from any of them but you'll want to reuse your heads if you're not sure whether the engine you're replacing it with is a regular DE or RevUp. RevUp heads will not work with a non-revup car without a lot of work so if you're not sure what you're getting, stick with what you've got and just use the short block.
Also make sure your new/replacement engine came out of a rear wheel drive car. We can't use front drive VQs from, say, a Maxima. Significant differences between the two. It needs to be from a G35/350.
Old Jan 12, 2013 | 11:31 AM
Tolboothwilley™'s Avatar
if you are doing a direct replacement you need to make sure its a non-rev vq35de
They are from all automatic G35 from 2003-2006
All 2003-2004 G35 sedans and coupes
All 2003-2005 350Z as well
Visually the easiest way to tell the diff between the non-rev and revup(2005-2006 6MT G35s) are the timing covers/cam covers. Make sure your motor you swap in looks like the NOV-REV pic below and not the REVUP.
Also, since you are 5AT, make sure you pull the pilot bearing if there is one in the motor - you won't get the trans in w/out removing it
NON-REV
REVUP
Old Jan 14, 2013 | 05:35 PM
onevoice's Avatar
Copy/pasted my response from a previous thread...
I recently replaced my 04 35x engine as well due to OC issue (130K mile on it)
The following should work:
Automatic: 03-06 sedan. For coupe (you will have to retain the upper oil pan from your current engine)
Manual: 03-04 (05 and 06 manuals were rev-up and they won't work)
My replacement was from an '05 coupe (30k miles) and I had to retain the upper oil pan from my 04x
Hope this helps!!
Old Jan 14, 2013 | 05:53 PM
Texas-G's Avatar
Hope this helps!!
thanks for the info!! so bascially its best just to stick to my year lol...i jsut hope the engine i get doesnt have the damn OC issue...its from a junkyard but they offers warranty for 60 days i belive or 30
Old Jan 17, 2013 | 12:19 AM
you don't have to stick to your year..just make sure its a vq35de from a:
2003-2005 350z (any trans)
2003-2006 5AT(auto) trans G35
2003-2004 6MT(manual) trans G35
Those are the only requirements. Look at the pictures I posted. If the timing chain cover matches the first picture you are good to go.
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
