DIY : Oil Cooler O-ring Replacement V35
Old Apr 25, 2013 | 04:16 PM
DidG35's Avatar
no way the replacement gasket I got goes on the inside rim of the cooler. Fits fine on the outside ring. Are there two separate sizes?
Old Apr 25, 2013 | 05:44 PM
Jaygotboost's Avatar
is the part # the same as the one pictured ? no other o-ring or other sizes for that type of oil cooler . should be just that very one installed in the same location as pictured . Is your oil cooler oem ?
Old Apr 25, 2013 | 05:51 PM
I have heard it called both ways
Old Apr 25, 2013 | 05:57 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
Look at this diagram,
21304 part code is the Oil Cooler O-Ring it's the only one, there is no other for these cars
http://grubbsinfinitiparts.com/nissa...5/J2130084.jpg
PREMIUM SPONSOR
it goes behind the oil filter housing (oil cooler)
Old Apr 25, 2013 | 06:30 PM
DidG35's Avatar
I got it finally. It's not exactly the "fit" I was expecting for an o-ring. Oil leak solved.
Old Jul 9, 2013 | 08:48 PM
FTM002's Avatar
Thumbs up O-ring sources
First, thank you for posting this excellent procedure. Second, I found the oil cooler o-ring (Dorman copy) at Rockauto for $4.50 delivered. ($2.77 plus shipping). The OEM Nissan part was available on Amazon for $10 plus shipping.
Old Jul 26, 2013 | 11:17 PM
silvG35's Avatar
sweet rte up, but one question? when i did mine i did all the steps correctly but did i have to to the coolant flush all over again? i did it because the G started to over heat again. i dont know if i missed a step or did something wrong but some help would gladly appreciated
Old Jul 27, 2013 | 01:17 AM
You have to bleed the cooling system, I'll post details tomorrow and get a mini write up ..stay tuned brotha , I got you ..
Old Jul 27, 2013 | 01:19 AM
silvG35's Avatar
Thanks bud !!!!
Old Sep 25, 2013 | 11:24 PM
richqcca's Avatar
DidG35, I have the same observation about the o-ring 21304JA11A not fitting the inner ring and looks like it would fit the other ring (the one Jaygotboost cleans with a Q-tip on the picture). So you did install in on the inner ring? I just can't picture it..... I have a 2005 G35, but I don't think it makes a difference.
Old Oct 27, 2013 | 06:38 AM
richqcca's Avatar
Found my issue. O-ring part number 21304-JA11A has 2 different size !
After struggling for too long trying to fit the O-ring part number 21304-JA11A bought on Ebay, I went to the dealer to but the same exact part.
After coming home, I found out the one fromthe dealer was actually smaller and fit snugly on the inner ring of the oil cooler. The one I bought from E-bay seem to only fit in the outer ring, where it doesn't belong.
The one from e-bay came was in Nissan OEM bag. just like one I bought at the dealer, not sure what happen....
Old Oct 27, 2013 | 07:45 AM
kpowe1's Avatar
I have to do this because mine is leaking. The dealer told me that it was the upper oil pan gasket and did mention the oil cooler gasket leaking.
Old Oct 27, 2013 | 12:58 PM
Step 5 / Picture #1 shows where the old o-ring in Orange is currently installed and new o-ring goes in exact same spot . Qtip was just me cleaning the whole thing
Old Dec 22, 2013 | 09:33 AM
  #30
Joeyxbat's Avatar
Doing my oil change change today, found out that I have oil leak. Glad to see this diy oil o ring. Btw, anybody know how to bleed the cooling system?
