Beefed up radiators, new fans?????
Old Mar 25, 2013 | 05:38 AM
guitarrocker98's Avatar
I'm just wondering if I get a new radiator do. Need new fans as well? There is close to no room up front with the turbo and everything else so will it all fit without slim fans??? Any help.
Old Mar 25, 2013 | 09:47 AM
gary c's Avatar
If you need a new radiator replace it with a aluminum unit and keep the OE fans. If it's not broken don't fix it, in you case it fits too!
Gary
Old Mar 25, 2013 | 09:52 AM
HotRodG35's Avatar
Most will go with aftermarket cooling fans/shroud with larger radiator
Mishimoto makes a nice setup that will compliment your radiator.
You can also upgrade to 14" fans later on if you have room and need additional cooling.
http://www.summitracing.com/parts/mio-mmfs-350z-03
Old Mar 25, 2013 | 09:59 AM
gary c's Avatar
Mishimoto radiators have a problem with fit, Koyo V series radiator will fit like a glove and designed to give you better cooling which is what you need since going FI....Gary
Old Mar 25, 2013 | 10:02 AM
HotRodG35's Avatar
Gary,
Wasn't referiing to the radiator but the cooling fan/shroud.
Old Mar 25, 2013 | 02:06 PM
Thanks guys. Neither are really "broken" but I have my whole front end off. I figure since its all off I might as well.m the fans are cheap... I'm going for a koto radiator on my350 now. Just have to make sure it will fit.
Old Mar 25, 2013 | 04:25 PM
So I found a koyo hr radiator that fits a 07 350z would that work? Any ideas. If not there is an aps one from z1 that I will probably buy and get new hoses.
Old Apr 4, 2013 | 01:16 PM
Well I posted this in another thread, but im torn between The Koyo, Mizu, and AMS. I heard there is fitment issues with all three. But Gary C and Pepper both said that the Koyo fit perfect. Im just trying to get a good radiator, and a set of hoses and I can then get my front end put back together.
Old Apr 4, 2013 | 09:54 PM
Lone Wolf's Avatar
I have the KOYO OEM replacement radiator for my G. The fitment is 100%!
Old May 21, 2013 | 03:07 AM
jonavalos93's Avatar
is the Koyo compatible with my 5AT
Old Jun 3, 2013 | 10:25 PM
TTBUILTG's Avatar
I have the Koyo racing radiator with Upgraded dual fans, it certainly is a tight fit,but i love it. They utilize all the oem fittings so you dont need any adapters or new drill holes or move anything remotely to another location.
Hope this helps everyone to decide.
Old Jun 3, 2013 | 10:28 PM
TTBUILTG's Avatar
http://www.ebay.com/itm/Infiniti-G35...6b8628&vxp=mtr
Here is brand new one for 164$!!! i have NO clue why its that cheap,its brand new, they usually cost 340$+ so you cant beat it!
Old Jan 10, 2014 | 06:49 PM
I decided not to grab fans, because I have no room haha
Old Jan 12, 2014 | 11:34 PM
ekrebs's Avatar
Yep!! Just need to run a external tranny cooler. Easy!
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
lavtxa
Sep 21, 2015 11:51 AM
mattdg35
Sep 14, 2015 11:28 AM
