omg. need help fast.
Old Mar 31, 2013 | 03:22 PM
hawaiian5's Avatar
Im stuck in the middle of nowhere. All kinds of things are happening. First off, yesterday my auto lights started acting up. It would go off and on but now its completely off. Car was running good until now. I start it, and all the lights on the display lights up. Slip, service engine, vdc is off. Car has no power. Barely moves. Someone please help.
Old Mar 31, 2013 | 03:33 PM
hawaiian5's Avatar
So now i start the car, and all the lights except the check engine is turned off. Something is happening to cause these problems but seems like its gonna be a problem that comes and goes. What do u guys think it is?
Old Mar 31, 2013 | 04:19 PM
Frankieg35's Avatar
Bad battery??
Old Mar 31, 2013 | 07:04 PM
hawaiian5's Avatar
I dont think so. I was able to scan it and a p1112 or p11122 code came up. Its one of those. Throttle relay short or something. But car is running just fine now. But I dont wanna take the chance. I wanna fix this problem but i really dont know how. Any suggestions?
Old Mar 31, 2013 | 07:27 PM
hawaiian5's Avatar
IIts code p1124 how do I fix it
Old Mar 31, 2013 | 07:41 PM
bluedevils95's Avatar
P1136 NISSAN - Intake Valve Timing Control Solenoid Valve Circuit Bank 2
Possible causes- Intake valve timing control solenoid valve bank 2 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 2 circuit connectors
P1124 NISSAN - Throttle Control Motor Relay Circuit Short
Possible causes- Throttle Control Motor relay harness is open or shorted
- Throttle Control Motor relay circuit poor electrical connection
- Fualty Throttle Control Motor relay
Old Mar 31, 2013 | 07:52 PM
hawaiian5's Avatar
Thx. Is this gonna be pricey to fix. If I buy the parts, I have a friend that can fix it. Sadly he's off island and wont be back till Saturday. He's doing the valve cover upgrade for me, ir plugs, oil change, trans fluid change and gear oil. He said if i get what ever is needed, that he can change it for me.
Old Mar 31, 2013 | 07:53 PM
hawaiian5's Avatar
OOne more thing, would a grounding kit cause any of this? I just put a kit on last week.
Old Mar 31, 2013 | 08:33 PM
faiz23's Avatar
Sounds like electrical issues and could have to do with a loose ground or forgetting to attach a ground. Check your IPDM box under the battery and make sure all the wires you touched and replaced are nice and tight. Did this start when you attempted a mod that only has a so called placebo effect. If you want to do a real upgrade than do the big three mod.
Old Apr 1, 2013 | 12:12 AM
hawaiian5's Avatar
I did the kit last week. Big 3 on this coming Friday. Everything is back to normal, but I do wanna try and fix whatever cause the code. I just dont wanna buy things that I dont need. I.E. ipdm
Old Apr 1, 2013 | 02:00 AM
Tolboothwilley™'s Avatar
Don't fix it if it's not really broken....sometimes you have electrical things pop up and never come back. If the problem persists then find it and fix it. For no just inform yourself of possibilities and find parts so if you need to yu know where to buy them
Old Apr 1, 2013 | 02:31 AM
hawaiian5's Avatar
Whold the ipdm from a 350z work? Or are they different I can get parts off of a 350z really cheap. To be on the safe side, what should I be looking for that i might need to fix this problem. One and only car, single dad, 40 minute drive from work this sucks! Lol
Old Apr 1, 2013 | 04:16 AM
achursin's Avatar
I had the same issue happen to my 05 coupe. Dealer charged $300+ to put on a new throttle body. Don't worry about the car loosing all power, it does so to protect itself i guess. Referee to as the "limp mode." The reason for my throttle body being replaced was due to aftermarket HID fog light kit...go figure, the dealer said somehow it was frying the throttle body.
Feffman
SouthEast
Sep 5, 2015 06:26 AM
JermaineSanders
Aug 18, 2015 08:57 PM
Feffman
Midwestern
Aug 16, 2015 08:08 AM
Feffman
Autocross/Road
Aug 16, 2015 08:07 AM
