NGK Iridiun IX Cooler Plugs
To all
Here is the part # for the one step cool NGK Iridium plugs # LFR6AIX-11
You get get them online here----->http://www.clubplug.net/retail_iridium_ngk.html
These are the best plugs for a FI car, or cars with alot of mods.
Hope this helps
David G
Hope this helps
David G
Originally Posted by USDM V35
To all
Hope this helps
David G
Hope this helps
David G
How hard is it to install these? Any tuning required after install?
yeah.. any instructions on how to install the sparkplugs?
I onced install sparkplugs on my 2002 honda accord, it was really easy.. they're right on the top part of the engine.. so it's very visible.. but on g35.. I can't see where the sparkplugs are located.
David,
I'll be doing a step by step on changing the plugs. I'll post it or E-mail it
to you soon. As far as programming I recommend resetting the ECU after install of
the new plugs and driving the car like you stole it for 5 mins so the ECU car
learn the plugs.
Randy and Vic,
learn the plugs.
learn the plugs.
Randy and Vic,
learn the plugs.
learn the plugs.
NHRA: National DRAGSTER (Racing Technology) (Issue 25, 1999)
I have done many spark plug changes on 4, 6 and 8 cylinder cars. The easiest I have done would be the Honda's and Acura's (as the plugs/wires are right on top). The hardest was on a V8 Olds Cutlass. I also changed plugs on a V6. I would imagine that since the VQ is a V6 that there would be 3 plugs on either side, easiest way to locate them is to follow the distributor cap and follow the wires to their home. I know to change plugs on some V6's you have to get 1 or more of the plugs from within the wheel well/fender as they are not too accessible under the hood. This can also be done from beneath the car. As I have not yet taken a close look at the wiring on the VQ I will jack her up tomorrow and try to post pics of plug locations to confirm.
Originally Posted by dklau33
How To Change Spark Plugs...
Originally Posted by pdjafari
wow you learn something new everyday! no wonder i never noticed a distributor in the engine bay...not like i really looked for it though...
Then I looked in the service manual and was pleasantly surprised.
