Transmision Question
Old May 8, 2013 | 06:34 PM
QuickG35's Avatar
Hey G Owners,
I have an 03 Coupe with an automatic. Does anyone have any problems with theirs? If so, about what millage will I expect it? I have about 85K on mine. Thanks.
Old May 9, 2013 | 12:12 AM
rcdash's Avatar
How often have you changed the ATF?
Old May 9, 2013 | 01:21 AM
QuickG35's Avatar
i always change ATF every 2 years. I have no problem with it right now. Just looking to see if anyone has problems with it and when do they start.
Old May 10, 2013 | 02:06 AM
Tolboothwilley™'s Avatar
Most automatics don't have issues til the 140-150K mark. If you maintain it well you should go beyond this. For extra insurance you should consider using an external cooler in series. The #1 cause for transmission failure (automatics) is from too much heat.
Old May 10, 2013 | 10:22 AM
socketz67's Avatar
Minus some of the programming issues the 2nd gen G 7AT had that were later fixed, our cars are not known for transmission issues other than normal wear and tear. Take a look at Consumer's Guide for instance. All the way back to 2003, we are pretty clean and rank up there with Toyota and Honda. The key is service and using the correct fluid (Matic-J originally, now Matic-S).
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
