FX35 shuts off after startup (post cleaning TB)
Old May 10, 2013 | 02:10 AM
L7nx's Avatar
After doing a lot of researching on the site i went ahead and carefully cleaned my throttle body and now after startup the fx just idles all the way down till it shuts off (unless i rev it)
I only removed the intake and intake hoses when i cleaned the Throttle body.
I did not remove the Throttle body from the plenum.
I only cleaned the outer TB, and i did not play with/move the butterfly. I also opted to disconnect the negative battery term.
Used cuetips and a microfiber cloth rag/TB cleaner.
I'm thinking i might have an air leak when i connected everything back? Or do i have to clean the MAF as well?
I tried to search this but i cannot pinpoint the issue.
Help appreciated
Old May 10, 2013 | 05:43 PM
L7nx's Avatar
anybody?????????
Old May 10, 2013 | 09:35 PM
saywat?'s Avatar
check make sure all the hoses are where they need to be
Old May 11, 2013 | 04:55 AM
Eric@TCGMiami's Avatar
I believe you may need to perform a idle air relearn procedure as when you rev the car it stays on but @ idle it stalls.
Old May 11, 2013 | 05:01 PM
L7nx's Avatar
i figured i'd give this a try, i can't get my timing right. how do you actually "know" when you did it correctly?
Old May 11, 2013 | 06:26 PM
When the engine turns on :P
( when you see the cel blinking )
Old May 29, 2013 | 12:51 AM
quanttrom's Avatar
I had a similar problem, the car wouldn't idle right and would stall once in a while.
When I took the TB off 90% of the gunk was on the plenum side. If nothing helps, try taking off the throttle body and clean both sides.
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
