KOYO V-core radiator & Vortech plumbing?
Old May 28, 2013 | 09:59 AM
joeb1983's Avatar
G35
Does anyone know if the KOYO V-core, 36mm radiator will provide enough clearance (with the stock fan shroud) for the piping of the Vortech kit?
I installed the radiator this past weekend along with numerous other cooling mods and just looking at it, it looks pretty tight.
The pipes are sent off for powder-coating, so I can not test fit, but as I said it does look pretty tight...
The reason I went with the KOYO V-core was due to it's description on their site. "Designed for applications where engine configuration/size cause clearances issues for thicker core radiators. In this case, the 36mm V-Core Series will suit your needs."
I searched and only came up with people suggesting this radiator, slim fans for others or any radiator upgrade for that matter. It fits like a glove and install went very smooth so I am very happy there. Let me know guys. As always, Thanks!
Old May 28, 2013 | 12:02 PM
guitarrocker98's Avatar
I believe there is a guy on the 350 forums that did it. I'm doing it soon, but I'm only turbo charged not super charged. So my piping and pulley systems are different.
Old May 28, 2013 | 07:44 PM
350z006's Avatar
I've installed a 36mm AMS radiator; heck I've even installed the 52mm big koyo with my Vortech setup. The trick is that you will need aftermarket slim fans in order to do this; don't even try and use the stock fans, although with a bit of plastic trimming you may be able to get the oem fans to fit with the 36mm, but I doubt it.
Old May 28, 2013 | 07:57 PM
joeb1983's Avatar
G35
Talked to Coz over at CZP. He said it would work with no issues with the 36mm. The big Koyo would require a slim shroud and fans or extensive modification to the stock fan shroud.
I got the pipes back from my powder-coat guy to test fit it as he is just down the street. At first I thought there was no way, but after removing the crossover coolant hose bracket, disconnecting the drivers side cam connector, dropping the front sway bar, loosening a oil line plumbed under the crank pulley and snipping off a fan wire harness tab on the shroud; I got it the drop in from the top with some effort. So it will work. Tight fit, but still enough clearance to work properly. Vortech seriously did a terrific job with the bends!
Old Jun 4, 2013 | 08:32 PM
joeb1983's Avatar
G35
Like I said. A little effort and it worked. Think she looks good!
seagrasser
May 3, 2022 09:43 AM
BradMD_96
Oct 6, 2015 09:31 AM
lavtxa
Sep 21, 2015 11:51 AM
Jorgebarrera
Sep 17, 2015 11:50 PM
