G35 hard to start when cold
Old Sep 15, 2013 | 11:37 AM
Streptomycin's Avatar
My 2003 G35 sedan has difficulties starting when it has been sitting. When the engine is warmed up it starts right up. It often takes several cranks to start when cold and I don't know what to check further. I scanned the car and it has no codes, it gets good mileage and power, I changed the spark plugs which I was sure would fix it, I changed the air filter, but the problem remains.
Anyone had this problem before?
Old Sep 15, 2013 | 04:21 PM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like a camshaft position sensor or crank position sensor is going bad. Those are common issues on our cars and will often start to fail before you get a SES. Take the car to an auto parts store to see if they can pull any codes. Read the thread right below this one, it'll explain a little better what I'm talking about.
Old Oct 1, 2013 | 03:02 AM
Stillen06coupe's Avatar
how old is the battery? batteries are rated much lower in cold cranking amps then they are with normal cranking amps... get your battery tested
vmcarbuyer
Oct 12, 2019 12:42 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
laksjd84
Jul 24, 2015 05:12 PM
