2nd engine rebuild: now will not start? Help!
Old Sep 19, 2013 | 06:46 PM
HereKittyKitty's Avatar
Engine torn apart, again, due to overheating issues. Refuses to start. Any help appreciated.
All internals changed out. Car still overheats, bubbling in the overflow, limp mode etc. It was decided to re-open and re-build the engine again. Will not start.
Old Sep 19, 2013 | 07:53 PM
Nate_6mt's Avatar
Your gonna have to give us a some more background and info on what' has and is goin on in order for anybody to even remotely attempt to help you solve this.
Old Sep 19, 2013 | 07:57 PM
PAIXAO's Avatar
Seriously, throw us a bone here
Old Sep 19, 2013 | 07:59 PM
Nate_6mt's Avatar
Lol..sadly I'm kinda interested now. Fill us in
Old Sep 21, 2013 | 04:33 PM
Anyone? Gary!?
Old Sep 21, 2013 | 04:48 PM
redpearl99's Avatar
lol, Gary knows everything these days???
Old Sep 21, 2013 | 04:56 PM
faiz23's Avatar
roflmao...thanks for the extremely detailed post. Paging Gary to the rescue. My personal opinion which is worth nothing compared to your buddy Gary. I would check out timing, cam shaft / crankshaft sensors. What are you getting and not getting. Fuel, spark, compression and what about your wiring harness. Are you going to a competent mechanic or not. Why do you have to tear into the engine again. Was it not done right the first time and you went back to the same mechanic.
Old Sep 21, 2013 | 05:35 PM
Your welcome. I have no friends. Just need help. I have not driven the car all summer. Get my point?
No known codes, ecm/ecu changed still no start. Non Infiniti rebuild. Not done right the first time, overheated, read the post I made.
Thanks, HKK
Old Sep 21, 2013 | 07:00 PM
redpearl99's Avatar
Gary has always had a good shoulder to cry on
He's very gentle and holds your hands during those rainy days
........joking
Old Sep 27, 2013 | 01:42 PM
ECM now working, still no start, so I'm told.
Old Sep 28, 2013 | 04:50 PM
Bump
Old Sep 28, 2013 | 09:25 PM
Eno's Avatar
Eno
Does it turn over at all? Just crank and crank- or does it just tick...
Old Sep 29, 2013 | 09:39 AM
From what I have been told, nothing. No noise whatsoever. Should we change all the sensors?
Old Oct 2, 2013 | 04:30 PM
Update: bad ground from engine to transmission. Engine was painted, this is the cause of current problems. Would this issues throw a code?
Engine being taken apart, again.
Old Oct 11, 2013 | 06:27 AM
Car cranks but does not start. No codes.
