2nd engine rebuild: now will not start? Help!
Old Oct 11, 2013 | 11:48 PM
Jtrain's Avatar
My first reaction would be to check the seals and studs, but I'm no mechanic or expert.
Head gasket would probably explain your bubbling and overheating... Are you using new gaskets with your rebuilds?
Old Oct 12, 2013 | 04:11 AM
jjyellow's Avatar
Does the motor turn over? You say motor doesnt run but you said motor over heated again? Check for fuel pressure or fire?
Old Oct 12, 2013 | 08:25 AM
HereKittyKitty's Avatar
Motor now turning over but will not start. No codes. Ecm has been changed along with several sensors, which ones I do not know. "Chain" had been misaligned, now fine.
This is the latest update.
Old Oct 12, 2013 | 06:09 PM
Bump
Old Oct 12, 2013 | 06:10 PM
Yes.
Old Oct 23, 2013 | 12:50 PM
Update: 2 codes, P0014 + P0011, changed both sensors. Car runs perfect, finally!
Ednica87
Sep 5, 2015 02:59 AM
andyg35c1
Aug 29, 2015 03:37 PM
chinee
Aug 8, 2015 10:11 AM
newg37
Jul 26, 2015 09:32 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
