Flywheel Torque Specs?
Old Sep 24, 2013 | 06:59 PM
arekieh's Avatar
Hey,
Planning on swapping my clutch and flywheel this weekend. I'm trying to find the flywheel bolt specs but can't find them anywhere, don't see them in the FSM, just says to reattach.
Also, should I be using loctite, and if so blue or red?
Thanks
Old Sep 25, 2013 | 01:19 PM
N8Deezy's Avatar
The FSM says to torque the bolts to 29'lbs.
Old Sep 25, 2013 | 01:27 PM
arekieh's Avatar
Isnt that clutch to flywheel?
I'm looking for flywheel to crankshaft
Old Sep 25, 2013 | 02:18 PM
black_gst's Avatar
http://lmgtfy.com/?q=g35+flywheel+torque+specs
oh look its the 1st result with an entire write up too
Old Sep 25, 2013 | 02:53 PM
N8Deezy's Avatar
That torque is 70'lbs. loosen, apply red lock tite and retorque to 70-75'lbs.
Hope that helps
Old Sep 25, 2013 | 02:54 PM
arekieh's Avatar
Oh look, its wrong info and debated later in that thread with no conclusive answer.
I searched for a good 30 minutes yesterday and couldn't find anything conclusive. Called JWT and they said 70 ftlbs, back off, add red lock tite then 75 ft lbs
OEM Spec is 60-65
For anyone that is looking
Edit*
Hope that helps
Thanks man. I guess I was getting overly paranoid. The guy at JWT (Ben I think) told me the info would come with the clutch/flywheel package. Mine should arrive Thursday hopefully, just trying to confirm everything before starting.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
