walbro help! >:
Old Nov 22, 2013 | 10:01 PM
dinojuice's Avatar
walbro help! >:
This walbro255 gss342 wont fit in my g,
its an 04 coupe,
I trimed the bottom 4 dashes, well everything it said here http://blog.cj-motorsports.com/2011/10/24/350zg35c-fuel-pump-upgrade-installation.aspx
I havent done the drilling just yet bcuz it just wont fit wen i put it all back inside the tank.
I even filed the 2 bumps next to the conector, and nada it needs like less than half an inch so It can fit .
What else do I cut, trim, file ??
Im pissed.
Old Nov 23, 2013 | 12:56 PM
jdm-v35's Avatar
how does it not fit? I, as well as im sure many people have put it in with no issue. it is barely bigger than an OEM pump. if it doesnt go back into the tank you probably are putting it back in facing the wrong direction or the hose is in the way(in the tank).
Old Nov 25, 2013 | 12:53 AM
N8Deezy's Avatar
its an 04 coupe,
I trimed the bottom 4 dashes, well everything it said here http://blog.cj-motorsports.com/2011/...tallation.aspx
Im pissed.
Rotate that puppy a little after you've verified nothing is causing a pinch point.
seagrasser
May 3, 2022 09:43 AM
g.spot
May 9, 2016 10:54 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
