Need help G35 SEDAN!
Old Dec 7, 2013 | 08:04 AM
teamghost's Avatar
My 04 G35 Sedan was having problems start up VDC SLIP and SES lights came on I checked for codes and P0345 came up so I went to go buy a Camshaft Sensor Bank 2 from AutoZone Duralast brand and replaced it and still same problem just that code (P0345) is showing up no other codes should I buy genuine oem Infiniti & try it or is it something else?
Old Dec 7, 2013 | 07:39 PM
JaE35's Avatar
Moderator
G35 Sedan
If you did any searching on this forum you'd see buying those sensors is a big no no. Have to go OEM with the cam sensors
Old Dec 7, 2013 | 08:04 PM
teamghost's Avatar
Yeah exactly why I'm posting this I saw that it's a common issue with after market parts and I even got a mechanic to check it out and hes saying that its my battery thats its too small but I bought my battery like a year ago brand new and never gaved me issues so I'm calling bs on dude but thanks just ordered genuine part from infiniti dealer hopefully that fixes my problem!
Old Dec 15, 2013 | 05:30 PM
teamghost's Avatar
Help please g35 sedan!
So check this out I recently was having trouble start my 04 G35 Sedan VDC SLIP & SES Lights pop up I scan and code P0345 (Camshaft Sensor Bank 2) comes up! I buy the sensor from AutoZone Duralast Brand Replace and still same issue I look up plenty of forums and they all said go genuine oem on sensors so thats exactly what I did ordered genuine oem nissan sensor bank 2 replaced it and still same problem hard starts don't get it I scan again and still shows up same code bank 2? Please Help what should I try thanks!
Old Dec 15, 2013 | 05:45 PM
Texasscout's Avatar
Might try resetting the ECU
Old Dec 15, 2013 | 08:29 PM
teamghost's Avatar
Did a reset still same issue lights came back on
Old Dec 16, 2013 | 03:46 AM
bythabay's Avatar
Couple of things: First, I almost exclusively use the aftermarket sensors and I have only had one come back bad after 2 years. Second, those camshaft sensor plugs are a real pain to remove and install back. You need to make sure the inside part of the connector pops back out after your reconnect everything, it has to be almost flush with the tail end of the connector. Another options is maybe the wrong sensor was replaced?
P0345 is the driver side, usually remove the throttlebody to replace it. I recommend leaving the TB connector plugged in and just move the TB out of the way.
Old Dec 17, 2013 | 09:49 PM
teamghost's Avatar
Okay guys so I installed again but this time when I unplugged the sensor I cleaned the hole where the sensor goes in blew on the connector for dust or dirt connected it all back made sure everything was real tight put throttle body everything back together and waa laah started up real quick as I let it warm up a little I was going to take it for a ride and as soon as I pressed the gas it turned of and I tried turning it back on and the same thing happens again makes the sound that its going to start but nothing whats going I'm loosing it i swear lol i love my g never gave me issues and defiantly don't want to get rid of it HELP!!
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
