Motor oil question.
Old Feb 7, 2005 | 11:16 AM
malx's Avatar
Motor oil question.
Mobil 1 Synthetic 10W-30 okay for an 03 6MT Coupe?
I also have an M1-110 Mobil one filter.
Old Feb 7, 2005 | 11:27 AM
JD_AND_DA_G_RIDE's Avatar
Post
If it's cold weather I'd stick to 5-30w as the manual recommends. Use 10-30 only for continous hot weather. The 5-30 is more fluid at cold temperatures. I'd stick to using a stock oil filter. I can't remember if the oil filter you're using has the anti-drainback valve in it. This helps the filter keep oil in it to prevent startups w/o oil or at least that's what it claims to do.
Old Feb 12, 2005 | 10:38 PM
Red Dragon's Avatar
The Mobil 1 oil filter does have the anti drain valve..It's the best oil filter when using synthetic oil ...
Old Feb 12, 2005 | 11:29 PM
dwoloz's Avatar
I use M1 5W30 SuperSyn with OEM 15208-9E000 (the non ****ty one)
I could use a higher viscosity since it never gets below 50F here but I figure Ill stick with whats recommended
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
JLee301
Sep 25, 2015 08:46 PM
Terry_G35
Sep 10, 2015 08:17 PM
UT G35
Sep 3, 2015 03:58 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
