2003 coupe snapped camshaft! and more need advice.
Old Mar 18, 2014 | 10:26 PM
Nylax16's Avatar
so my project car is becoming more of a project than i thought,. originally i assumed id do complete swap. today i took the motor down to the heads. found one of the drivers side camshafts is snapped right under the first(towards the front of the car) U bracket that holds the shaft in place. the passenger side of the lower intake manifold had a ton of carbon build up. while the drivers side was clean the center cylinder was full of fuel. i think the heads are shot and im worried about the block . gonna take the heads off and check it out tomorrow. but as of now this is what i got.also it had a kenitx plastic intake manifold that was cracked in half...... when i put a new battery in it today the car started but would only run if i held the gas down. also found the passenger side coil pack (center) was not even tightened down and the rear coil pack was seperated as well. ... im thinking i should just swap or buy a rebuilt block/heads off ebay from engines usa for $1700... unless anyone out there has had this and has advice on the next move....
Old Mar 18, 2014 | 10:29 PM
Frankieg35's Avatar
Damn, how the hell did all that damage happen??
Old Mar 18, 2014 | 10:32 PM
Nylax16's Avatar
no clue man bought the car as a project. girl had it so it had bad maintence i assume.. she was driving it in the summer n it sounded like **** so i knew the intake mainifold was cracked.. but i assumed the valves got stuck open and made the cam stick n it snapped..
Old Mar 19, 2014 | 06:55 AM
Nylax16's Avatar
bumpyy
Old Mar 24, 2014 | 01:00 PM
Tolboothwilley™'s Avatar
replied in your other thread - but i have a spare set of heads i'd sell
Muski_G
Dec 1, 2023 11:11 AM
realtalk21
Jul 20, 2015 09:07 AM
Thaaa_king
Jul 18, 2015 05:56 PM
driftsucky
Jul 15, 2015 12:38 PM
