clutch issues
Old May 20, 2014 | 09:04 PM
codeman200's Avatar
clutch issues
hey guys I need some help yesterday I was driving and the clutch just fell to the floor has no spring back I can pull it back with my hand put just falls back down if I press on it had to get it towed home, any ideas whats broke? Thanks!
Old May 21, 2014 | 03:27 AM
N8Deezy's Avatar
Check if the clutch fluid reservoir had fluid in it? If it's empty you ain't getting no return after you press the clutch down. And if you somehow manage to get the car in gear it's very dangerous because you won't be able to get it out of gear without forcing it.
Also trace the lines from the clutch master cylinder to the slave cylinder for leaks.
It'll take a few minutes to check both.
Old May 21, 2014 | 01:09 PM
codeman200's Avatar
okay will do, thanks!
Old May 21, 2014 | 03:01 PM
Texasscout's Avatar
Yes, mine did that, flush the system, no problems since.
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
NemesisGee
Aug 11, 2015 07:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
