You know the old Question? Injen & water?
Old Feb 12, 2005 | 04:18 AM
RacerX35's Avatar
Well I was driving down this street while talking to my wife(on the phone). The water was getting pretty deep pretty quickly from what I could tell, and about 10ft. from getting to higher ground the engine shut down. Every other car drove around me, including little Civic's and such. So I sat in my car for about 45 minutes waiting for a tow truck to come and pull me out. By the time the tow truck got there, the water had pretty much run out of where I had been stranded. Now the car is sitting at the dealership waiting to be checked out on Monday. Worst case, the engine needs to be replaced and hope that the insurance covers it. If not, it will be about $11,000.00 for the replacement. In the mean time, they did give me an '05 sedan for the loaner (only 414 miles on it when I drove off the lot.), with an empty tank. Hope this doesn't take too long. On a good note, I'll have a '05 motor in the car.
Old Feb 12, 2005 | 11:26 AM
ZeroGen's Avatar
Omega Enthusiast
Yikes, hydrolock!
Sucks to hear about it, but good luck.
Old Feb 12, 2005 | 11:57 AM
snakes1021's Avatar
saw an 04 vq35 for 2g's on ebay. 2200 miles. good luck wiht that sorry to hear that.
Old Feb 12, 2005 | 03:56 PM
visualfusion's Avatar
The reason I'm scared about the InJen intakes... =(
Old Feb 12, 2005 | 03:59 PM
jim@streetimage's Avatar
You can turn your Injen CAI into a short ram intake during the winter so you have nothing to worry about. That is what i did to my car.
Man Sorry to hear that. I hope everything works out for you.
Old Feb 12, 2005 | 06:53 PM
sushmaster_g35's Avatar
it isnt the injen intake...its all cold air intakes...the answer, BYPASS VALVE...a little saucer looking thing made by AEM to go in the middle of the intake pipe, makes the hydrolocking problem WORRY FREE...just ordered a CAI and the bypass valve because I am not going to sacrifice my $11,000 for 10 hp...GET IT...ONLY 50 BUCKS...WORRY FREE
Old Feb 13, 2005 | 02:38 AM
skeleton_cru's Avatar
Sedan
How deep was the water you drove into? Did it submerge the cone filter?
Old Feb 13, 2005 | 04:58 AM
RacerX35's Avatar
I'mnot sure exactly how deep it was, but when a couple of cars drove around me after it stalled, I could hear the water hitting below the car. By the time the first tow truck came and pulled me out, the water had gone down a bit. But it was still at the lower half of his shin. Shushmaster, while I was at Riverside Infiniti, I saw that they had a coupe on display in the showroom. It just happened to have an AEM CAI, I didn't see a bypass valve though. And I also saw a display case with headers and all sorts of other aftermarket goodies.
Later,
Ray
Old Feb 13, 2005 | 07:30 AM
glennp_1999's Avatar
Don't believe the bypass valve is going to make your car worry free. You will loose HP with that thing installed. You might as well not change your intake if you want worry free operation.
Old Feb 13, 2005 | 10:08 AM
pfizzle's Avatar
Short ram... Is the way to go.. btw if you have to spend 11k on a vq35, you minuswell do an RB swap for that much..
Old Feb 15, 2005 | 05:11 PM
RacerX35's Avatar
Good news guys. I talked to Riverside Infiniti today. I was told that they pulled the spark plugs and attempted to crank the engine. When they did, all six cylinders blew water. They've been running the car and testing it, all is running smooth last I heard. They also said that they are going to do a compression test to make sure that all the cylinders are fine. So with fingers crossed, I'll be able to pick up my car soon. Oh! They also told me to go ahead and let my insurance know just in case something happens later, I have record of it.
Later,
Ray
Old Feb 15, 2005 | 06:03 PM
copbait's Avatar
Sorry to hear about your probs, hope it works out.
Yet another reason why the stock airbox/ztube + K&N is the best setup!
Old Feb 19, 2005 | 07:34 PM
the AEM doesnt come with a bypass valve it is a separate buy...and no, you don't lose power because wen it is dry the foam is out and it is just like a completely straight through tube, but as soon as water gets in there the foam immediately puffs up and blocks water going through the tube, thats wen it might lose power, but maybe for 2 seconds
Old Feb 20, 2005 | 01:20 AM
G35STUD's Avatar
umm question, why did u drive thru 10 feet of water, you just need to be more careful about that, I have an Injen cold-air and i drive thru rain all the time, its just how deep you have to watch out about.... sorry to hear tho... best of luck, look on ebay cuz u can get the engine cheaper than from dealership....
