Engine Bay Harness
Old Jun 12, 2014 | 07:37 PM
Bluv73's Avatar
Engine Bay Harness
I got an 07 g35 coupe AT that was hit in the front end got all the body & radiator condenser & everything together & just notice that they must clipped wires to fan & headlights & just need to know what's the best way to go with it or will a g35 sedan wire harness will work or manual g35 will work?????
Old Jun 12, 2014 | 07:46 PM
Bluv73's Avatar
Engine bay harness
07 g35 coupe AT wrecked in the front & they must cut some wires to the harness cause there no plugs to plug into the fans & headlights so I'm stuck & was wondering is the harness for other 07 g35 (manual or sedan) will work
Old Jun 14, 2014 | 11:31 PM
Chillichinchill's Avatar
From my experience, you need to get the part number off your harness, (You can call the dealership and ask for this by giving your VIN) and go on e-bay or some recyclers website. Item number must match, if it doesnt it wont fit.
On another note, IF you still have the plugs, you can just take it to some mechanic that deals with wiring and ask him to rewire, or you can simply do this yourself.
Old Jun 15, 2014 | 12:03 AM
Bluv73's Avatar
I've called like 3 dealerships & all said they don't give out part #'s and 1 even said dont splice the wires, my car is wrecked in the front & all I really need is the headlights & radiator plugs
Old Jun 15, 2014 | 12:15 AM
herrschaft's Avatar
^Contact OC Infiniti, their information should be somewhere on the forum. And there's nothing wrong with splicing the wires as long as they're spliced correctly. Not sure where to get just the connectors though.
Old Jun 15, 2014 | 12:27 AM
Bluv73's Avatar
Thanks for all replies, I got an 05 harness so if I cut off where. The headlights on both sides I should be ok
Freeman186
Sep 6, 2023 10:07 AM
Danielek
May 1, 2022 01:28 PM
zcherub
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
