Basic Mod List
Old Feb 15, 2005 | 09:52 PM
Ippo's Avatar
Basic Mod List
Level 10 or stillen valve body upgrade
Maybe a torque converter
Crawford cast plenum
Popcharger or whatever + Z-tube
Stillen engine dampener brace
Maybe a set of sway bars
Headers of some kind, maybe DC or stillen
Stillen cat-back, which is apparently loud, sound is not a big deal to me
Grounding Gear
Maybe TC ECU flash, not sure
What do you think a guesstimation of typical gains might be?
Old Feb 16, 2005 | 08:25 AM
cato's Avatar
SouthernComfort Moderator
Grounding Gear
I believe the consensus opinion here is that 20 HP is the most you can get with bolt on mods, short of going Forced Induction. So, if you did all of the above, around 20HP.
Old Feb 16, 2005 | 05:06 PM
dwoloz's Avatar
Thats a ton of money for 20HP
Might as well go FI
Old Feb 16, 2005 | 05:52 PM
BombRush's Avatar
Basic I got were z-tube, K&N dropin, tinting 20% all the way, clear side corners, and getting stoptech BBK
Old Feb 16, 2005 | 05:58 PM
Brando's Avatar
I'd say it can be a bit higher.
This is the info from one of our group members..Rug Rat Coupe.
But....he has invested a chunk of change......
RugRatCoupe/Performance Mods
Polished CRAWFORD"Z"Plenum, R.T.Cats, NISMO Flywheel, NISMO Perf.Clutch, NISMO P.Plate, STILLEN Exhaust w/X-Pipe, INJEN Polished CAI, HYPER GROUND Wires, EIBACH PRO-KIT, NISMO SwayBars, JDM NISMO/RAYS/S-Tune 19" LMGT-4's, BRIDGESTONE S-03's. Cut Down Engine Cover, R.E.Short Shifter, PENNZOIL/LUCAS Synth.Oil, Snow/Aqua-Mist Water-Methanol Injection, U.R.Crank Pully, T.S. ECU...
268.3whp/251.6tq. 1/4 13.86@101.38/60' 2.126 all #'s before W/M Inj
Old Feb 16, 2005 | 06:24 PM
DrPJM1's Avatar
And just how much hp did you get with the tinting 20% all the way and the clear side corners?
Seriously, IMHO our engine has been well-developed and it takes FI to realize serious performance gains.
Old Feb 16, 2005 | 06:27 PM
Sundeviljay's Avatar
This is just my opinion....but unless you are actually racing your car, why not spend all the money on making your car look better and get better accessories such as interior and electronics instead of making your car go 0-60 in .7 seconds faster?
Old Feb 19, 2005 | 02:05 PM
RacerX35's Avatar
I don't know. I was dyno'd at 254.5 rwhp with just:
* Injen CAI
* UR pully set
* JWT flywheel
* Stillen dual exhaust
Now I've added:
* Kinetix Plenum
* Top Speed headers
* Kinetix high flow cats
Now I haven't had a chance to dyno since then, but it sure feels like I've gain a bit more hp over the last dyno. Base line dyno's are like what, 231-233 hp usually. So I've already gain more than 20 before the plenum, headers and cats. Of course I still need to dyno to get the results and see if I lost or gained anything. But then again, my G is in getting the transmission replaced. And since it's in I'm going to have the clutch replaced. I'm planning on a JWT clutch. Now depending on the dyno as well, you can show some serious gains. I dyno'd on a dyno-jet (at STILLEN), and some other guys dyno'd on a (dyno-pak?) I think it was called. But some of them showed up to I think 276 rwhp. That's well over a 20 hp gain. Of course some one may correct me, I don't know. But, this is my opinion.
Later,
Ray
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
NohoG35revup
Aug 22, 2015 12:13 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
Ninjay16
Jul 20, 2015 01:21 AM
