Motor swap help.
Motor swap help.
After of 3 years of fun and joy.
And 120.000km,recently broken water pump and a transmission that is about to give in I decided to swap the motor/transmission and make the sedan a fun toy.
My question is what motor should I swap it for(year) and what transmission since they are different when it comes to ECM.
It's a 2004 sedan,not the 2004.5 so I believe I don't have the "standalone" ECM (don't have full control of gear when in tiptronic mode)
Upgrades/replacement
I will look for a motor with under 100km.
What things do you guys suggest changing on the motor before swapping it in?
For the transmission:should I rebuild the current one with stage 10 kit or get another transmission and put a shift kit it in an call it a day?
Time/budget: 3000-4000$ with a month of time that I can live without the G.
All advice will be appriciated.
Thanks you
Thanks you
magnetism80
Jan 27, 2016 12:57 PM
