2004 G35 Startup clanking noise
Old Jan 15, 2015 | 12:46 AM
bentrimbey's Avatar
Exclamation 2004 G35 Startup clanking noise
Hey, first time poster here.
I have a 2004 G35 sedan with nearly 198,000km's. Ever since I got the car about a year ago it has made this noise on nearly every startup. The previous owner said it happened with him as well. As soon as I start the engine it makes this awful clicking noise for about 2 seconds and then goes away. After the initial click I don't hear anything else. I originally thought it was the timing chain tensioner, but I'm not sure.
My biggest worry right now is that this noise is doing horrific damage to my engine. Also, on cold winter mornings (-15 or colder) the car produces A LOT of white smoke for about 30 seconds and then it normalizes. When I say a lot, I mean like a thick barrel of pure white. As well, I have a bad case of oil consumption. I change my oil every 6 months and during that time I have periodically add ~3.5 litres of oil. I use 5w30.
Please, If anyone has heard of or experienced this issue, help me out.
Posted videos as well to show the noise on 2 different occasions. The temperature outside during these 2 videos was roughly 3C
Old May 1, 2015 | 09:30 AM
h20poloman's Avatar
Nobody replied to you sorry.
Here is the possible problems,
It could be the primary chain tensioner that is slacking slightly as the car does not have oil pressure when its off.
Guides can also be worn to the point that they don't provide the necessary tension.
When the pressure goes up then it creates tension as this is how the tensioners work.
Usually when timing chain components are worn or faulty enough there will be noise at all times.
The VQ35de is known to have this issue with the Intake cam sprockets.
TSB:
http://maxima.theowensfamily.com/tsb/ntb03-060.pdf
That link is for altima and maxima. But it also plagues all VQ's as its the same engine,
The dealer will tell you its normal if you take it there.
A lot of folks just drive the car like this, as this is not something that will cause the car to jump timing if this is your problem
Now if your problem is in the timing chain components, then that is another story.
Good luck,
Old May 1, 2015 | 09:39 AM
danoman32's Avatar
Back from the deeaaad....
Old May 1, 2015 | 09:41 AM
h20poloman's Avatar
Only been dead for a couple of months not too bad
Lol
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
