No start - weak spark?
Old Feb 8, 2015 | 05:55 PM
Eldo's Avatar
Hi all,
I'm working on diagnosing a no-start situation with my 2006 G35 coupe. The car cranks but won't turn over.
My first thought was the battery, since that was going on 5 years old. I went ahead and replaced that with no luck, now I'm trying to be more systematic in identifying the issue.
I got a spark tester on one of the coils and it seems like the interval between sparks is a bit long. Here is a video of the car cranking with the tester. You can't see the sparks too well but you can hear them. Does it seem like the sparks are not frequent enough?
I hooked up a OBD2 code reader and there are no codes.
Depending on what you all think, my next steps are to either check if I am getting fuel pressure, or to work backwards on the ignition if the spark is not fast enough.
As a side note, would something like this work to check the fuel pressure? Or will I need an adapter? It looks like that one is for schrader valves.
Amazon.com: OTC 5630 Fuel Pressure Test Kit: Automotive Amazon.com: OTC 5630 Fuel Pressure Test Kit: Automotive
Terry_G35
May 9, 2020 01:39 AM
mtlruss
Dec 20, 2015 01:51 PM
yassy
Aug 9, 2015 07:31 PM
Terry_G35
Aug 4, 2015 02:38 PM
Rehman2009
Jul 27, 2015 03:23 AM
