Shifter shaft spins..wtf?
Old Apr 28, 2015 | 11:31 PM
ScraggleRock's Avatar
So, not sure if anyone's changed their shift **** with a new OEM one, but the OEM one is just as hard to get fully on as it is to get off.
Anyway, I had vice grips on the shaft, but when I was getting close to it being fully on (with my very strong arms) something gave and now the shaft can spin. What did I break?
Old Apr 29, 2015 | 01:14 AM
WhosUrBuddiee's Avatar
Hahaha
Old Apr 29, 2015 | 02:24 AM
Originally Posted by WhosUrBuddiee
Hahaha
Haha fukc you, man. I know we're supposed to hate eachother, but wtf..?
Old Apr 29, 2015 | 02:49 AM
It still works perfectly. All gears are fine, everything goes in straight, quick and easy (giggity). Its just that I can spin the shifter shaft now. Obviously I don't want this happening, and worse case scenario I just get a 350z shifter, but if its an easy fix I'd like to know what it is.
Old Apr 29, 2015 | 08:59 AM
The shift shaft is a single piece. If it spins, then your "very strong arms" broke something. If the shaft itself is spinning and not the ****, then it is only a matter of time until it disconnects from linkage and your stranded.
Shifter shaft
Old Apr 29, 2015 | 01:16 PM
This is the only thing I could find that's even remotely close to whats going on. In this pic there is a pin in the housing and a groove on the shifter literally there just to keep it from spinning. This is not a Nissan shifter tho. Found a Toyota site with a similar "pin" conversation tho. Guess I'm taking it apart today..
Old Apr 29, 2015 | 01:40 PM
JHereth22's Avatar
Scragglerock stop "drifting" haha
Old Apr 29, 2015 | 01:53 PM
VQ35 shifter is not like that. Just order a replacement shaft and swap it out.
Old Apr 29, 2015 | 05:01 PM
Alright, I fixed it.
The shaft is actually two pieces held together (seemingly) with compression. I somehow broke the bond (with my strong arms) causing the top half to spin. Once I took it apart, the top half just came right off. I seriously don't see how they were held together..there are no clamps, pins, crimps or anything. I think the factory just compressed the sleeve side over the shaft side (bottom half)
I just used some red locktite and crimped the sleeve onto the lower half of the shaft. It ain't goin anywhere.
Old Apr 29, 2015 | 05:15 PM
^^ Thank you. You are the first and only person I have ever seen disassemble the shift shaft. Great knowlegde to know.
Old Apr 29, 2015 | 06:11 PM
Well it kind of disassembled itself. Hahaha
Old Apr 29, 2015 | 06:16 PM
Before (don't know how the hell this happened. Jersey thinks it was previous owners right hand ring collection. Seems legit)
After (new boot too; thanks itpro2002..wherever you are.) Haha
Old Apr 29, 2015 | 11:40 PM
Lartytiejdke3's Avatar
Before (don't know how the hell this happened. Jersey thinks it was previous owners right hand ring collection. Seems legit) After (new boot too; thanks itpro2002..wherever you are.) Haha
why you didn't go with a black one as you progress towards you black interior swap I'll never know..
Old Apr 30, 2015 | 12:28 AM
I'm never gonna do that. I'm not patient enough. Plus, it was the willow one that was for sale.
Old Apr 30, 2015 | 12:51 AM
JHereth22's Avatar
I've got a black shift ****, and shift assembly if you want it
