What's needed for manifold
Old Aug 11, 2015 | 10:18 PM
lowG's Avatar
I want to fully polish my intake manifold but I know once I take it off I have to replace seals. What seals and how many? If those are the right questions
Old Aug 11, 2015 | 10:24 PM
ScraggleRock's Avatar
Your plenum or manifold? Plenum you don't need anything. The manifold you should just need the one (or two?) gasket(s) between the manifold/heads. I suppose you could change the injector seals while its all out, but other than that you shouldn't need anything.
As long as you've got it off and polishing it, you may wanna gasket match the intake ports...if you're not scared...haha
Old Aug 11, 2015 | 10:32 PM
lowG's Avatar
Wait what's the difference between plenum and manifold..
Old Aug 11, 2015 | 10:36 PM
The plenum is the big squarish thing that you see when you take off the engine cover. It's got the throttle body connected to it..6 bolts on top..
The manifold is under that and has the fuel rails connected to it.
Old Aug 11, 2015 | 11:32 PM
bigc's Avatar
Wings Nation
You don't need to replace your gaskets, but a motordyne aramid gasket would be a nice upgrade over the stock one if you plan to remove your lower plenum:
http://www.motordyneengineering.com/...products_id=50
When you put your plenum back on, be sure to follow the torque specs and tightening order in the service manual. Also make sure the little rubber ring around the oil filler doesn't get stuck between the upper and lower plenums...it happens to a lot of folks.
jsimonk
Dec 22, 2023 03:49 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
socalg35x
Aug 7, 2015 09:36 AM
bjo16
Aug 4, 2015 09:52 AM
newg37
Jul 26, 2015 09:32 AM
