Replacing Head Gasket after over heat - Planing heads?
#50
Thanks guys, feels good to be back on the road.
I'll definitely keep you updating as I break her in and put more miles on.
Shouldn't be too bad doing a normal rebuild. My main worry was how the removed material from heads/deck would affect clearance, compression and timing and also making sure I didn't have any oil leaks from the numerous RTV seals and O-rings.
Right now I have no idea where that blue plug goes, but there doesn't seem to be a problem with it. If someone knows that'd be helpful. Also I have a misfire (or two) most likely from my Einstein coilpacks which are made up of my original coilpack top and some other nissan stalks/springs. I don't actually have a CEL/MIL but I am pretty sure the miss is due to the coilpacks. I never did anything back to the throttle body, not sure if that might cause a problem - haven't 'calibrated' it or anything.
#51
Tonight I drove about 6/7 miles out to the store, when I was 4/5 miles on my way back home the temp was going up a couple notches quickly so I shut her off and pulled over. I was on the highway doing around 70 cruising. Found a hose had disconnected and dumped the coolant. Connected hose back, filled with water, took just over a gallon to fill the rad and top off the expansion tank.
Started back up and drove about a half mile before I see the needle going back up again.
Any suggestions? I'm hoping it's as simple as needing a coolant bleed (just threw in water at the side of the road) but maybe the water pump is out? Put about 40 miles now on the engine
#52
-Ali
BradMD_96 (11-29-2015)
#53
#54
Before bleeding out the system I flicked the a/c on to find my fans stationary. Giving them a push got them going, one stopped back, so I found what I am sure is the issue. I am thinking this is why the car overheated in the first place with the PO and probably while I was driving it the first time.
I opened up both fan motors to find 2/4 brushes stuck on one and 3/4 on the other. I took the brushes out, cleaned all the carbon powder and lubricated the brush holders/sliders. We had a 350z back in England and the same thing happened to those motors.My brother wrote up a thread here with how to fix them.
http://www.350z-uk.com/topic/69810-h...s-youtube-vid/
#56
I agree. Had the same happen to me. Only one fan would be spinning with the AC on idle. It would begin to overheat. Swapped the cooling fan rack and its been good since.
You can find the whole rack or individual motors on Amazon Prime. The individual motors are around 40 each and the whole rack is around 90 or so.
(individual fans)
I tried finding the fans locally and they were pretty expensive. Decided to one day ship these out from Amazon and swapped them the next day.
About a 15-20 min job to do it. The top radiator cooling line has to come off to slide the old rack out.
Let us know how it goes!
-Ali
Amazon.com: TYC 620980 Infiniti/Nissan Replacement Radiator/Condenser Cooling Fan Assembly: Automotive
(the whole rack)(individual fans)
-Ali
BradMD_96 (11-30-2015)
#57
I opened both up, cleaned what needed cleaning, refitted and they work fine when I flick the a/c on and should be fine on the road. Waiting on a pair of coilpacks before I drive much further.
#58
Why not just get some coilpacks from autozone or something? One of mine broke and just replaced it with a duralast. Works fine.
