05 g35 cranks but wont start
Old Dec 17, 2015 | 01:51 PM
alexp96's Avatar
my 05 g35 sedan just had the driver side valve cover replaced they put everything back together and the car wont start I took it to infiniti got new key programmed to see if it was that but it wasn't so they put it on the computer and its not showing any codes and they don't know what it could be took it back home and tried starting it with starter fluid and turns on for a sec or two sputtering can anybody help me
Old Dec 18, 2015 | 10:55 AM
telcoman's Avatar
Veteran: Army
Originally Posted by alexp96
......... tried starting it with starter fluid and turns on for a sec or two sputtering can anybody help me
Not enough gas in tank?
Fuel pump?
Test fuel pressure
Telcoman
Old Dec 18, 2015 | 03:59 PM
alexp96's Avatar
full tank but supposable it doesn't have an injector pulse that what one mechanic told me not sure
Old Dec 18, 2015 | 04:32 PM
telcoman's Avatar
Veteran: Army
Find a qualified mechanic that can read and follow the FSM
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/fl.pdf
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/ec.pdf
See page EC-676
If all injectors are failing did you check for a blown fuse?
Telcoman
Old Dec 21, 2015 | 02:28 PM
alexp96's Avatar
yes all fuses are good and relays also.
Old Dec 21, 2015 | 03:09 PM
ciraleon's Avatar
I just had this issue. I thought it was the fuel pump at first. Come to find out my gas gauge wasn't working properly and I didn't have enough gas.
I wish the gas gauge issue would be figured out already. Not even the Infiniti in my area knows what to do except to replace my entire cluster. Eff that.
Old Dec 21, 2015 | 03:20 PM
alexp96's Avatar
I wish it would be just that but that thing is filled up to the top
Old Dec 21, 2015 | 03:33 PM
ciraleon's Avatar
I'd take off the lower back seat and see if the fuel pump is even engaging. The fuel pump is pretty cheap to replace and shouldn't take you more than 2 hours to replace...
Old Dec 21, 2015 | 04:23 PM
alexp96's Avatar
yea its kicking on
Old Dec 21, 2015 | 06:44 PM
mushu's Avatar
I would recheck how the hoses and vacuum lines are put back to make sure they go in the right place/order. Good luck!
Old Dec 22, 2015 | 02:59 AM
telcoman's Avatar
Veteran: Army
Did you check the fuel pump pressure with a pressure gauge?
Telcoman
BradMD_96
61
Jan 18, 2016 05:56 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
Bdrago86
Oct 13, 2015 11:49 AM
the93owner
Sep 28, 2015 10:37 PM
