Exhaust leak between engine and headers
Old Dec 17, 2015 | 06:29 PM
AhmadH's Avatar
Hello guys, please I need help.
I have aftermarket headers. Does a leak in the gasket between engine and headers will cause temperature to be higher? Also bad gas mileage? Also higher engine sound?
If these are blown?
If there is a leak in the circled area?
Old Dec 17, 2015 | 09:52 PM
andrewvk's Avatar
just fix it.
if you put anti-seize on the studs and bolts you can pull it off fix it and toss it back on in under an hour.
just remove the stud on the lower right and you can lower it right down.
Old Dec 17, 2015 | 10:49 PM
gary c's Avatar
Headers must be tightened down in sequence from the center out! If this wasn't done correctly you may have a blown gasket or warped headers, not what you wanted to hear! Both issues will make noise and have little to do with gas mileage...Gary
Old Dec 18, 2015 | 12:41 PM
LoSt180's Avatar
Yes, it sounds like the gaskets have blown out. Blown gaskets will make the exhaust sound funny, and affect gas mileage due to turbulence reducing the exhaust efficiency.
Just get it fixed.
Old Dec 20, 2015 | 02:56 AM
EPiK's Avatar
When I first got my car the headers had several loose nuts, gas mileage was bad, and I always smelled exhaust fumes in the car. it took a little bit of work to reach them on the passenger side, but fix it, it's worth it.
shochan808
Jan 16, 2016 04:04 AM
Jonconusaf
Dec 26, 2015 01:31 AM
jsmith29
Dec 10, 2015 11:09 PM
2Infinitinbyond
Nov 18, 2015 09:34 AM
sotex_G
Nov 4, 2015 04:34 PM
