03 g35 vq37 swap ... Not your typical wanna know info thread
Old Jan 31, 2016 | 07:59 PM
yosip1115's Avatar
Originally Posted by GTR203
Of corse I'll take you for a spin , if you ever want pop by my shop during the build fellow nissan enthusiast are always welcomed. As far as mounts go it seems like different threads say different things. That 03-04 arnt right and 370 arnt right, I'd have to use z33 hr mounts. Regardless it was only 70 bucks and now I have all three sets so one has to work.
Better yet.... We should line em up (On a track of course...) Get a tune on that 3.7 and it'll be quick for sure!
If I have some spare time I'll pop in during the build. What kind of time are you able to put into it? You a 9-5 guy too?
Old Feb 1, 2016 | 11:47 AM
GTR203's Avatar
I was a 9-5 guy I took a break from the real world I like to say and started doing work at my shop more full time so right now im at my shop everyday usually after around 4-6 I'll stop working on customer cars and start mine.
Old Feb 1, 2016 | 09:42 PM
yosip1115's Avatar
Sounds like you have something good going... Nice collection BTW!
Old Feb 4, 2016 | 01:40 PM
CV35Driver's Avatar
Very Interesting Thread. Subbed!
Old Feb 12, 2016 | 08:44 AM
GTR203's Avatar
Got some progress done , not as much as I had hoped because I had jumped over to my other project rx7 that's almost done and finally got that fired up, I'll tell ya two plus projects at the same time is a bit draining lol.
Here's the rx7 as I am chasing wires
Old Feb 23, 2016 | 08:55 AM
GTR203's Avatar
Finally some progress! Spent the last few days pulling engine , cleaning prepping vq37 , measuring where everything should sit ect . Installed 07 350. (Hr) rack, 07 350z motor mount brackets and original vq35de mounts. Test fits and she fits like a glove. As of now I'm waiting on my long tube headers, lw flywheel and a few other odds and ends . Next will be drive shaft and have the harness done, I've been saving my pennies and I'm bout halfway saved up the 2400 needed for the harness I'm going that route as its plug and play and eliminates any headaches or worrys and its all immobilized .
Picked up some new cheapie wheels to play on, this car will be drifted all this season, no use running 4K wheels
Old Mar 20, 2016 | 03:21 PM
sammy_G's Avatar
That's awesome.
keep it going!
Old Mar 20, 2016 | 07:32 PM
DeafBringer's Avatar
long overdue for an update! Can't wait to see where you're at with this.
Old Mar 20, 2016 | 11:39 PM
yosip1115's Avatar
+1
Can't wait to see some progress. I will do this if you pull it off... These engines are good for way more power than the DE.
Old Mar 31, 2016 | 12:39 PM
Nickk6's Avatar
Cool build! Hows it goin?
Old Apr 24, 2016 | 08:00 PM
.cakestar's Avatar
updates?!
Old Jun 13, 2016 | 06:28 PM
Jimster480's Avatar
Whats going on with this?!! Looks awesome!
Old Jun 13, 2016 | 07:36 PM
GTR203's Avatar
Sorry for lack of updates I actually moved to Florida for a little bit then ended up moving back home as I found out picking up and moving isn't quite as easy as it seems , I've gotten quite far actually I'll post some pics up in the next few days I got everything permently mounted trans in shifter in headers on ect ect. Cooling system is done, fueling is done. Then we get to the hard part, the wiring. I figured easiest way to go about this is run the car completely with 370z wires. Every last one, also ended up going with 370z dash and everything surrounding it. 370 hvac, 370 steering colum , 370 full brakes including abs, and just about everything else. All the wiring is basically done I'm at the point now where I am fitting the dash setup. I've had to trim the dash sides for the doors to close as it hung out too much, and I've cut both cars dash supports to make one. Sides where it mounts are g35 rest is 370 so the dash lines up. The only harness I didn't use was the rear of the car which now I'm wishing I did. When I left off I was looking for wire diagrams for the plugs on each car that go to the rear so I can match them up and power all the lights and fuel pump ect. I did save the plugs from the hr mess so once I match them up I'll have an oem 370 plug connecting them.
Old Jun 13, 2016 | 08:24 PM
Newtown06's Avatar
wow, lot of work! So you did not use the Zfever 'plug-n-play' wiring harness? any reason?
Nice swap!!!
Old Jun 13, 2016 | 09:29 PM
  #30
GTR203's Avatar
Didn't wanna drop the 2400 when I had all the parts from the parts car , plus it updates the outdated interior
