Hotchkis installed... few days later knocking sound?
Old Feb 24, 2005 | 12:45 AM
g35noob's Avatar
a knocking sound has suddenly appeared coming rom my rear sways i think. this happen to anyone else out there?
Old Feb 24, 2005 | 01:38 AM
JKDman's Avatar
Knocking noise? From my experience, if it IS coming from the hotchkis sways, it's gonna be a "creaking" or a "rubbing" noise. It's most apparent when you're going over speed bumps or taking on an incline (like a driveway)
It's from the bushings. Whoever installed your sway bars, didn't lube it up enough with Lithium Grease. It needs to be laid on there pretty damn thick.
When does the sound go off?
Old Feb 24, 2005 | 06:11 AM
g35noob's Avatar
i can hear it whenever i turn. i installed it myself so i guess its possible i didnt put enough. but i thought i put alot. since it was an amateur install i suppose there are alot of ways i could have messed up
Old Feb 25, 2005 | 03:39 AM
rock's Avatar
I'm not sure if this would work for the g35s, but white teflon tape instead of grease worked well on my Acura TL-S Comptech sways.
Old Feb 26, 2005 | 11:30 PM
leegina's Avatar
Also check the torque on your swaybar links. If they are not properly torqued they could make that clunking sound. Just my .02
MyfistYourFace
Aug 8, 2015 11:58 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
rping
Jul 26, 2015 09:53 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
vstypicals
Jul 20, 2015 10:55 PM
