Camshaft Position sensor
Old May 4, 2016 | 11:11 AM
davidf66's Avatar
Has anyone used aftermarket camshaft position sensors? I bought an 04 G35 for my daughter for $3k. It has 193K miles which doesn't bother me much since I've owned 8 Nissan vehicles in the past and I've never had any real issues. Aftermarket sensors are about half the price of OEM. Your thoughts???
Old May 4, 2016 | 11:28 AM
Lartytiejdke3's Avatar
buy the oem ones.
Old May 4, 2016 | 12:17 PM
VenomGT9's Avatar
buy the oem ones.
Old May 4, 2016 | 12:26 PM
davidf66's Avatar
Well I guess that settles that. That's for the input guys...
Old May 4, 2016 | 12:44 PM
ScraggleRock's Avatar
Hold up, hold up.
I never got this: the OEM Campos sensors are the ones known for NOTORIOUSLY FAILING. Why ya'll trying to go buy another piece if ****?
OP, I have one of those regular autoparts store ones and it has never given me a problem. Plus you get that lifetime warranty shizz..
Old May 4, 2016 | 01:18 PM
Texasscout's Avatar
mine lasted ten years.....
Old May 4, 2016 | 01:58 PM
VenomGT9's Avatar
Stock has lasted me 100k and I'm only changing them to prevent the future issue
Old May 5, 2016 | 03:01 AM
Well, just so we're clear; I've had aftermarket and OEM and so far the OEM is the only one that's failed me. It'll be awhile before I can compare one to the other 'apples to apples' (or mile for mile) tho.
Point being is that the Nissan one has ALWAYS been a problem. I'm just not sure why everyone is so eager to replace it with the known failure version. Like I'd never put Nissan rotors up front again either; Fug that noise. Nor would I put their garbage comp rod bushings..
Old May 5, 2016 | 04:26 AM
EPiK's Avatar
Originally Posted by ScraggleRock
Hold up, hold up.
i replaced my cam pos sensors when i got my 2003 coupe at 106k miles as preventive maintenance, used the local parts store ones, also for the easy access warranty. do the spark plugs while you are in there and check on the valvecover gasket and spark plug tube leakage.
Old May 5, 2016 | 09:52 PM
saywat?'s Avatar
sensors arent supposed to last forever man. if it goes it goes. its not like it goes often usually people just change once and its good to go for awhile. people suggest oem bc its works best and doesnt cause any up front issues like aftermarket ones. maybe not last forever but it lasts a pretty long time
Old May 5, 2016 | 09:59 PM
saywat?'s Avatar
come to think of it i dont recall reading much about people changing oem cam sensors more than once in the cars lifetime. ive only had to change it once. anyone else?
Old May 6, 2016 | 03:34 PM
Velix's Avatar
I used the one out of my 05 to put in my 07. That sensor might see 300k, if it does I will cast it in bronze and mount it on my wall.
Old May 6, 2016 | 03:41 PM
saywat?'s Avatar
plus the part number has been superseded at some point which means some kind of improvement was made
Old May 6, 2016 | 03:50 PM
Urbanengineer's Avatar
Any of them are good. I'm 115k on original left with 15K on aftermarket.
Old May 27, 2016 | 10:44 AM
Cyoc62's Avatar
OEM or aftermarket
I guess everyone has an experience, so here's mine. My passenger side (U.S.)/ driver side (***) went out. I replaced it with an aftermarket piece. Since then, my idle seems to be higher, especially on "slower" drives, and in stop and go traffic.
The idle rarely drops below about 750 rpm, except after highway speeds. Then it seems to behave until it cools down, then it goes back up.
