Is this CAM sensor or Valve Timing Control Solenoid?
Old May 26, 2016 | 11:08 AM
Chriswf's Avatar
Yesterday my SES light came on.
Below is a pic of the report AutoZone came up with.
Before I went, I ran the codes on my own and got p0011 and 0300 (using self diagnostics).
Then I reset the codes and drove around till the SES came back on (then stopped by AutoZone)
Symptoms:
Rough engine idle.
Weak performance.
Really bad gas mileage.
Exhaust sounds horrible at 3-4k RPM. Sounds like my G has the flu.
I replaced the CAM sensor 2 or 3 months ago. The car worked fine until yesterday.
Do you think this is CAM sensor or the VTC solenoid?
I got an oil change yesterday AFTER the light came on.
Should I pull the VTC and clean it? I'm not worried about the replacement cost though.
My oil was honestly a little dark...
Old May 26, 2016 | 02:24 PM
infinitidude's Avatar
The fact that it has a p0300 multi cylinder misfire code trailing the p0011 makes me think you may have a bank 1 intake sprocket stuck at full advance which is around 64 degrees or so. You would have to take front timing cover off to replace it. It would be a better help if we could see the intake timing on both banks when the code is set.
Old May 26, 2016 | 04:51 PM
Chriswf's Avatar
I'm going to another part store this evening to see if 0300 is still there.
How do I get the timing on both banks?
And forgive me for not knowing, but isn't the intake sprocket the thing the timing chain spins?
Edit: Sorry I reread the reply you sent me. So you think the gear skipped a tooth or something?
Edit #2: I researched the timing cover removal. 20+ bolts? Is there even room to do that in our engine bay?
See my picture below, I circled what I think you're talking about lol.
By the way, thanks for your help.
Old May 26, 2016 | 06:49 PM
Chriswf's Avatar
I found this online:
p0300. The VTC solenoid gets energized at 2k+ RPM. This pushes a little piston into a resevior of oil. Through some mechanism, this rotates the intake cams and changes the timing. The piston in my solenoid was getting stuck in the energized position, even when the RPMs dropped and the voltage to the solenoid was not being applied. This means the cam timing was advanced on one bank and not on the other. At this poing the ECU and physical cam timing were on different pages, causing a misfire
An article about p0011 codes.
https://g35driver.com/forums/engine-...rror-code.html
Old May 28, 2016 | 07:54 AM
The sprocket you have circled in the pic is the exhaust side. The intake sprocket is the one next to it.
Old May 28, 2016 | 07:59 AM
I don't know where that pic is from but that is not a VQ35DE engine in the pic. The intake sprockets are not right.
Old May 28, 2016 | 11:19 AM
Chriswf's Avatar
That's fine, at least I know what you're talking about now.
I'm more likely to replace the engine if I have to repair that. That's 20+ bolts, pulleys, oil pan, gaskets, and a chain kit (might as well if I'm in there).
I can direct swap an engine on my own if I'm in there.
I'm going to check plugs (b/c I never have), clean MAF sensor, swap the autozone cam sensor out anyway (b/c the autozone employee even told me they don't last 3 months and I should buy it from infiniti), and I'll go from there.
Old Feb 24, 2020 | 11:12 PM
G35driverdude's Avatar
2005 g35 sedan
Same here
What did it end up being also throwing both codes.
Old Feb 25, 2020 | 10:50 AM
Chriswf's Avatar
There was a time when I had an issue with the cam sensor. So I just replaced that. It takes 10 minutes.
However, the error would come back again later... I believe it was just dirty oil. An oil change and driving it for a bit should make it go away.
The VTC solenoid is an unlikely culprit, far more unlikely than a Cam sensor.
Old Jun 14, 2021 | 05:21 AM
DoctorShafty's Avatar
G35 Coupe - New Engine - Sport Package - Auto
Hello, did you end up finding the problem?
david.stefanson
Apr 23, 2023 08:33 PM
J_Burna
Jun 7, 2019 09:46 AM
edwinisdumb15
SOCAL Meetings & Events
Sep 2, 2016 03:31 PM
rdozier
Apr 17, 2016 06:09 PM
kurier44a
Mar 20, 2016 04:57 PM
