Whats the best Intake
Old Feb 28, 2005 | 02:37 PM
DaveB's Avatar
Originally Posted by robbdogg
After a lot of reading here - I decided to go with the Ztube and the stock airbox and a K&N drop in.
Smart move.
Old Feb 28, 2005 | 02:57 PM
Dizz's Avatar
I 2nd that move.
Old Feb 28, 2005 | 04:01 PM
madchef's Avatar
Based on past experience with my Maxima and with info found here, I descided to keep the stock air box as well.....but I am looking around for a different option for the filter. Perhaps a urethane foam based one...not sure yet.
Old Feb 28, 2005 | 04:22 PM
MrBillMartin's Avatar
Originally Posted by BirdMan
Really? So you lost low end in the combo of the spacer and Stillen Air Box? I've got a Kinetix V4 Plenum with Z Tube and Stillen Box and its a match made in heaven! Definitely noticed an increase in power across the band however it did take some time for the vehicle to fully adapt after the instal and ECM reset. Couple of weeks maybe until it reached its full potential.
i agree 100%. if you are going to replace your upper plenum i recommend not staying with the stock intake. First i installed the z-tube; like everyone else i noticed the same thing (an addicting sound). months later i installed the kinetix plenum, with noticable gains and greater volume. Then weeks later i installed the stillen airbox. "match made in heaven" coudnt of been said any better. there is absobluly no loss in power. and sounds incredible. absobulty no complaints.
without a new pleneum things may be different with just the ztube and aftermarket intake. i too have read that you are better off with a ztube and the stock intake with k&n fliter. i cant argue with someting i do not have experience with, due to the order of my installs. but i can say again, if you are changing the upper pleneum do not stick with stock intake.
Old Feb 28, 2005 | 05:02 PM
Dizz's Avatar
From what my friend says, cotton is the best material to use. He said that foam can be just as restrictive as paper.
Old Feb 28, 2005 | 05:33 PM
BrianV's Avatar
Really? So you lost low end in the combo of the spacer and Stillen Air Box? I've got a Kinetix V4 Plenum with Z Tube and Stillen Box and its a match made in heaven! Definitely noticed an increase in power across the band however it did take some time for the vehicle to fully adapt after the instal and ECM reset. Couple of weeks maybe until it reached its full potential. I've got a Coupe Stock Intake System with filter, less then 500 miles total on the whole system. I live over on the East Coast however, so if you can't find one locally, I'd be more than happy to ship mine out to you. Keep me posted!
For what it's worth, I noticed loss of low end with the z-tube + Stillen CAI without a plenum or spacer. Also, I didn't think the engine felt as smooth and I wasn't as fond of the noise. I think overall it performs better with the stock box, and total power under the curve is higher than that of an aftermarket intake. These are only my opinions from driving the vehicle. I didn't do any real conclusive tests. I just felt like it slightly robbed power down low and it wasn't a massive gain on top. That coupled with the higher pitched noise (I much preferred the deeper, muffled tone of the stock box), and the fact that I could sell it for decent money resulted in me returning to the stock box. Fact is, even for free I wouldn't put any other intake on.
I will likely go with the spacer, but I'm waiting for the rush to calm down; make sure people are happy with it, etc.
Old Mar 1, 2005 | 12:05 PM
robbdogg's Avatar
Originally Posted by DaveB
Smart move.
Thanks!
This weekend I'll be putting them on the G along with the plenum spacer - can't wait!
Old Mar 1, 2005 | 12:32 PM
Dizz's Avatar
My car is so much happier with the stock air box.
I picked up a K&N drop in last night, life is good again.
Old Mar 1, 2005 | 02:24 PM
BirdMan's Avatar
Yea that whistling noise can get annoying at times, but hey at least you know physics is at work and the venturi effect is doing its job . With the addition of the Kinetix Plenum, it made the entire engine sound completely different. The material the V4 is made of (still don't know what the hell it is) really allows for sound resonance and gives the engine an awesome growling tone, especially in the lower RPM's. Higher up in the band, it just sounds plain mean! True, all in all everyone has there own opinions (CAI vs. stock with K&N) and I doubt there's much of a difference between the too, but I'm happy with my setup.
Old Mar 1, 2005 | 02:34 PM
Dizz's Avatar
Originally Posted by Dizz
For sale: Stillen CAI, used for 3k miles.
Make a reasonable offer.
Local pickup only.(Orange County CA.)
Bump
Bump
Bump
Old Mar 1, 2005 | 02:41 PM
ak-47's Avatar
Noob to G35
May I ask how hard it is to put the K&N drop in filter? Is there a tutorial on here that will lead you step by step? Thanks
Old Mar 1, 2005 | 02:47 PM
Dizz's Avatar
Easier than installing any CAI.
Disconnect the MAF.
unscrew the front portion of the ztube or stock tube.
remove air box.
undo the hinges holding the filter in
put new filter in
put everything back together.
done.
Old Mar 1, 2005 | 03:08 PM
moto35's Avatar
can somebody please tell me the cheapest place to purchase the ztube? thanks a lot.. can't wait to order it and start these mods.
Old Mar 1, 2005 | 04:48 PM
DaveB's Avatar
Disconnect the MAF.
remove air box.
put new filter in
done.
Funny question because I've never attempted it, but how do you remove the airbox. Everything seems to be be secured by plastic rivets.
Old Mar 1, 2005 | 04:52 PM
  #30
Dizz's Avatar
Pop them off... I forgot that you have to pop off the air duct in the center of the car, then proceed.
