Rear Differential Year-to-Year Compatability?
Old Jul 9, 2016 | 09:50 AM
FALSTEN's Avatar
Rear Differential Year-to-Year Compatibility?
Hi all,
I've been searching for this info with little luck, so thought I'd ask. I need info on what year differentials can be used as a replacement in my 2007 G35S 5 AT sedan.
Other than the rear end issue, it"s running great at 190,000 miles. Had a leaking pinion seal replaced about two months back, and it ran great for about six weeks. Then, suddenly one morning, I hear a slight gear noise, and it's progressively gotten worse, so I think I'm gonna be in the market for a new rear end and will probably pick up a low mile used unit if possible. Of course, that means a newer year model to get low miles.
Any help is appreciated!
Old Jul 9, 2016 | 10:05 AM
herrschaft's Avatar
Any diff (pumpkin) from a g35 will work. Your diff should have 4 bolts connecting it to the driveshaft, some G37 diffs only have 3 bolts. All of the manual G37's had a 4-bolt flange.
Old Jul 9, 2016 | 10:31 AM
FALSTEN's Avatar
The flanges that connect to the driveshaft can be swapped; correct? I'd rather find one from a late model G37 if they are compatible in order to have a better chance of low mileage/wear.
Old Jul 9, 2016 | 03:43 PM
herrschaft's Avatar
Yes the flanges can be swapped with some modification, but its easier to just get one that bolts-on directly.
Thaleague
V36 Audio, Video & Electronics
Nov 7, 2017 01:41 AM
Jason Koch
Mar 10, 2016 02:22 AM
Kingppoppy
Mar 3, 2016 12:00 PM
Kingppoppy
Feb 27, 2016 12:22 AM
Gary U
Feb 25, 2016 08:19 PM
