G35 fuel filter
Old Sep 5, 2016 | 07:20 AM
QX1's Avatar
QX1
G35 fuel filter
As to me was told and read one old thread that g35 fuel filter is non serviceable, thus meaning it lasts lifetime of a car. Fuel pump neither is seviceable, but in 125000 miles is the end of the pump sometimes earlier. last 2 cars the pump started make noise in more-less 125000 miles, first was Nissan maxima 3.0 A32 and second is G35 2006. So wiseguys who claim it lasts lifetime of a car is plainly mistaken. Also if drive lifetime of fuel filter it will kill your spark plugs much faster then usually. i just recently discovered that my car has fuel filter and it should be replaced by time especcially after 100k.
Old Sep 5, 2016 | 07:45 AM
telcoman's Avatar
Veteran: Army
I traded in my 06 G35 6 speed manual at 171796 miles. Never had a fuel pump or fuel filter problem
Telcoman
Old Sep 5, 2016 | 07:56 AM
QX1's Avatar
QX1
G35 fuel filter
My car engine is like jumping time to time during driving. anyway it shuld be changed at least 100k.
Telcoman
Old Sep 5, 2016 | 08:01 AM
QX1's Avatar
QX1
And by the way I see here mentioning several g35 owners have repl. their fuel filter already at 50k miles and 65k miles!?
By the way Telcoman I did not not know how your car was driving, the fact that you were driving 171k miles, it does not mean it is top shape.
Old Sep 5, 2016 | 08:15 AM
gary c's Avatar
No where in our service manual does it recommend changing the fuel filter! If the fuel pump has issues then replace it like everything else that wears out! NBFD
Gary
Old Sep 5, 2016 | 08:25 AM
QX1's Avatar
QX1
I think in coupe you cannot replace FUEL FILTER AND NEITHER THE PUMP. Cause it is in one unit. But in sedan it can be replaced and as somebody said it is not serviceable, it means should be changed
if there aroses need for it. In coupe if pump starts make noise you replace like one unit but in sedan you can change pump separately and filter. And by time the filter gets dirty, there are plenty of examples about it. If your car tank is dirty then is also your filter dirty.
Old Sep 5, 2016 | 08:28 AM
QX1's Avatar
QX1
Also , it there is no need to replace it, why Infiniti web-shop sales the filter separately, for example discountinfinitiparts.com?
Old Sep 10, 2016 | 07:08 AM
Blue Dream's Avatar
I drove ttrank's car solo
Like Gary said why replace it if it's not bad, that's horrible advice. Following that train of thought why not just go ahead and replace every part on your car now because it "might" go bad, smh.
He's a long time member who's respected on here for his knowledge and maturity so I'm pretty sure his car is well maintained. No need for you to be a d!ck.
Contradict yourself much? This whole thread is full of so much fail all I can think to say is:
That is all......................
Old Sep 10, 2016 | 07:14 AM
QX1's Avatar
QX1
G35 fuel filter
Most of your reply is photos,
Old Sep 10, 2016 | 08:19 AM
telcoman's Avatar
Veteran: Army
My vehicle was in top running shape and ran perfectly. It not only had the original fuel pump and filter but the original clutch, starter, alternator and all other OEM parts. Plugs were replaced at 106k miles.
It had 53 oil and filter changes 48 of which were done by me. No wasting money on synthetic oil or premium fuel.
I don't mind spending a little more on having a dealer do all needed repairs because any work that was done has always been done correctly the first time and I get a free loaner when necessary.
It needed its second set of brakes replaced, drivers side headlight ballast, and a leaking differential seal and tires.
I do not spend money on ridiculous and unneeded repairs such as replacing a fuel filter at 50k miles or replacing manual transmission fluid.
I decided not to spend the money on repairs and traded it in for my current 2012 G37S.
I'm glad that I did.
Perhaps someone out there bought it at auction because that is where the dealer sent it.
On my current 2012 G37S I decided to no longer do oil changes and the twenty oil changes thus far have all been done at my local dealer. They also wash and vacuum and return my vehicle cleaner than when I left it.
Telcoman
Old Sep 10, 2016 | 12:07 PM
QX1's Avatar
QX1
G35 fuel filter
G35 owners who live in country where fuel quality is disastarous change fuel filter very often. for example one G35 owner from Georgia(not USA) Georgia is located near Armenia, has done it several times.
Telcoman
Old Sep 12, 2016 | 08:08 PM
apolloautolight's Avatar
Hello ,
If you are still looking for a ballast check out our website we have great prices .
Telcoman
Old Sep 17, 2016 | 06:10 AM
Blue Dream's Avatar
Holy thread jack..............
Old Sep 17, 2016 | 06:22 AM
Blue Dream's Avatar
You know they say "A picture is worth a thousand words" right? And you obviously need to have your eyes checked 'cuz last time I checked my pics had words that carried a message to your dumbazz........
Annnnnnd they're still there. Keep it up and you might get the:
Did you get that message??
Old Sep 17, 2016 | 07:43 AM
QX1's Avatar
QX1
G35 fuel filter
I can add here also the photos of my fuel filter, how dirty they were inside, to explanation tosomebody that they do not need to replace.
Attached Thumbnails G35 fuel filter-img_20160912_140844.jpg   G35 fuel filter-img_20160912_140856.jpg   G35 fuel filter-img_20160912_140944.jpg
