Best fuel system cleaner? Do they even work?
Old Feb 28, 2005 | 12:46 PM
csukoh78's Avatar
What is the best (recommended) fuel system cleaner you guys have heard of? I have 35K on my coupe and feel I should do this just because I have seen carbon deposits on other engines, but all the cleaners swear they are the best.
Any objective findings? Any recommendations from professionals? Anyone had really good, noticeable results?
Thanks
Old Feb 28, 2005 | 01:01 PM
acerys's Avatar
I use Motul fule system clean and engine clean
Old Feb 28, 2005 | 01:32 PM
csukoh78's Avatar
Results?
and what kind of accessory lights are those in the bottom valence grills?
Old Feb 28, 2005 | 01:34 PM
BirdMan's Avatar
In no way am I a professional and call me old fashioned but I've always been a proponent of using Chevron Gas with Techron. True, its just gas however I do believe that Techron significantly helps. On my previous high mileage vehicle, I calculated out better gas mileage when I used Techron as opposed to other gasolines. Of course that could be entirely situational and may have nothing whatsoever to do with the Techron, but who knows. Anyway what can it hurt?
As far as additives are concerned, I've been pleased with Lucas products. Relatively inexpensive and they get the job done.
Old Feb 28, 2005 | 03:53 PM
P_Diddy's Avatar
I just reviewed my little spreadsheet where I track my gas mileage. It looks like I get slightly better mileage (~1-2 mpg) when I use 76 gas, vs. Costco & Arco (I was out of town & needed gas!). I've only used Chevron once but it was the same as w/ 76.
Granted, driving conditions & style vary, but here's the MPG averages since I've had the car (Aug '04):
Chevron 19.5
Union 76 19.3
Costco 17.8
Arco 17.6
Old Feb 28, 2005 | 03:59 PM
copbait's Avatar
I only put 76 or Chevron into my vehicles, good stuff
Old Feb 28, 2005 | 04:16 PM
badtziscool's Avatar
I read in a R&T article a while back and they did a test on various fuel treatment brands, and they tested STP Complete Fuel System Cleaner as most effective. They had some before and after pics and it showed how much cleaner the pistons and valves were. I was actually inpressed.
Old Feb 28, 2005 | 08:50 PM
infiniti4life's Avatar
Chevron is great... It cleared up an injector issue I had in my Jeep... Chevron is the best gas you can get, in many cases Dodge/Chysler trucks it in for test drives on their proving grounds...
Old Feb 28, 2005 | 09:12 PM
WolfsterX's Avatar
**WARNING**
Here is what the manual said in the book:
"Aftermarket fuel additves: INFINITI does not reccomend the use of any fuel additives such as fuel injector, octane booster, intake valve depositi removers, etc.). Many of these additives intended for gum, varnish or deposit removal may contain active solvent or similiar ingredients that can be harmful to the fuel syste and engine."
So, i would advice you guys not to use the aftermarket fuel additives. Kinda waste of money and just use higher octane fuel such Octane 91 or higher (knock-free). That is all you need.
Old Feb 28, 2005 | 09:26 PM
maxpower's Avatar
if you are using 93 octane as recommended, you should have no need for additives
Old Feb 28, 2005 | 09:37 PM
lawboy05's Avatar
Hands down....Proguard Fuel Injector Cleaner by Chevron! $6.99 at Walmart. Great stuff!
Old Feb 28, 2005 | 10:32 PM
ballisticus's Avatar
I agree. A case of 4 of those at Costco is $7 or so. I put one in after every 7500 mile service. Smooth as glass at 52000 miles.
Old Feb 28, 2005 | 10:34 PM
amg35's Avatar
Florida G35 Club
I know of one Infiniti dealer that uses BG 44k fuel additive as part of their fuel injection cleaning. I have heard good things about the BG products in general; don't know if it is good marketing or truly a good product.
Old Feb 28, 2005 | 11:58 PM
csukoh78's Avatar
Anywhere to get BG44K other than the dealer?
Old Mar 1, 2005 | 12:29 PM
lawboy05's Avatar
I have used the BG products line as well and I believe the Proguard is just as effective.
