Engine rattles when accelerating
Old May 10, 2017 | 06:00 PM
austin12387's Avatar
it rattles during a cold startup. Then noise goes away when it's warm idling. It rattles when I accelerate past 2k rpms and stops when I let go of the gas. This is starting to scare me, please help. (2003 g35 coupe 5AT)
Old May 10, 2017 | 07:00 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
What kind of gas are you using? Could simply be detonation from low octane gas.
Old May 10, 2017 | 09:02 PM
I'm using premium (91) all the time. My cel came up and the oil light blinked for a second and then vanished. Going to get it scanned and do an oil change. I will post my results later.
Old May 10, 2017 | 10:59 PM
Turns out I was low on oil as it barely came out as I was draining it. Watch your oil level guys!
Old May 11, 2017 | 05:25 AM
telcoman's Avatar
Veteran: Army
Don't you ever check your oil?
Telcoman
Old May 11, 2017 | 10:50 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
VQ35 = check oil every 500 miles.
Old May 11, 2017 | 01:12 PM
LoSt180's Avatar
That rattle is from low oil not keeping up pressure for the timing chain tensioner. Briefly on cold start up is normal as the tensioner needs to build up pressure. When it does it while accelerating I know it's time to check my oil. Also if oil level is good, then I know it's time to change it, lol.
Old May 13, 2017 | 04:44 PM
[QUOTE=telcoman;7105320]Don't you ever check your oil?
The dipstick on mine isn't good. The reading isn't accurate. I don't have the rev-up so I thought it wouldn't suck up oil as much.
Old May 14, 2017 | 08:11 AM
parapraxis24's Avatar
I guess I got a good example when I picked up my 03 back in January. After a 1400 mile road trip with 8-10 passes on The Dragon, I was only 1/4 quart low, or less.
Old May 17, 2017 | 05:30 AM
Blue Dream's Avatar
I drove ttrank's car solo
Scott's example is kind of a joke but it underscores a great point. ALL motors should have their oil checked every other gas fill-up to make sure they're good to go. It takes one minute and could be the difference between a blown engine and a happy one.
Old May 17, 2017 | 12:57 PM
Harman Sekhon's Avatar
Hey guys, i have a quick question. When i drive my 2007 g35 sedan aggressively and stop at the lights it begins to rattle and the sounds coming from the back. i got the resonator removed and have magnaflow mufflers can that cause the problem? or is it something else?
Old May 21, 2017 | 12:02 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Can definitely cause the problem, with the system cold jack up and support the rear, climb under and tug around on the exhaust system to see if anything is loose, pay attention to the hanger brackets to see if the supporting bushings are broken or any undercarriage damage from bottoming the car out. Also check each section of the exhaust for broken welds but you will almost always HEAR that kind of damage with the car running.
If you still can't find it YouTube search for the sound a broken muffler baffle makes, might be broken on the inside.
