04 g35 coupe engine problem
Old Sep 2, 2017 | 07:31 PM
tmatics's Avatar
Angry 04 g35 coupe engine problem
so a mechanic told me my cars lifters are bad but i read that the cars dont have lifters it has shims. well if thats the case what needs to be done to fix this ticking ? pull motor out ? leave it what all needs to be done because the ticking is starting to irritate me very badly
Old Sep 3, 2017 | 02:04 AM
Urbanengineer's Avatar
Post a video, but it may be worth heading to a Nissan specific mechanic.
Sometimes it's cheaper to swap a motor than it is to rebuild one.
Old Sep 3, 2017 | 04:15 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah lifters are a part that's used on pushrod driven valves, this engine has overhead cams and it uses a system of shim caps that the cam rides on, it's a pretty painstaking process to do a valve adjustment on this motor.
However, we really need a video to HEAR this ticking sound, it's might not a lifter, remove all your coil packs and inspect for damage, verify your spark plugs are properly torqued, I've seen a LOT of misdiagnosed valve noise that was actually a loose spark plug.
