2006 G35 Coupe, 145K Turns Off Randomly
Old Nov 6, 2017 | 09:11 PM
G35stephen's Avatar
Hello,
First time I've used this forum for help, thank you in advance!
I have a 2006 G that has 145K miles of bone stock parts on it and running strong. A few months back the car died on my while idling, got the car to fire back up and no issue since. Yesterday I was driving on the highway and it felt like the car sputtered a few times about 5-10 min apart, almost like a spark blow out feeling. Got off the highway and pulled into a drive thru, car died. She started right back up again and was fine until this evening, died out twice on the way home. First time was at a stop light and the second was rolling into a stop, car started right back up each time. After this the car had a few lights come on in the dash, check engine, VDC and slip were all on. After pulling the codes i erased them and was able to make my 30 min drive back home without any issues. Only other issue it has ever had is it takes more than a normal amount of cranks before it fires over.
Codes: All of them were on there twice
P0345 - Cam Position Sensor
P0159 - Slow Response O2 Bank 2
P0158 - Rear O2 Bank 2
P0157 - Rear O2 Bank 2
Thank you for your help!
-Stephen
Old Nov 6, 2017 | 09:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like a cam sensor to me, all those others was probably the sputtering causing extra fuel to be spat out the exhaust. Pull exactly which code P#### it will tell you which bank the sensor is failing on.
Word of advice, buy a new one from Nissan (or OEM dealer) don't get an aftermarket one, people have terrible experiences with them usually.
Edit: whoops, P0345 that's the driver side intake, it's one one with the angled connector not the straight connector.
Old Nov 6, 2017 | 10:26 PM
G35stephen's Avatar
Thank you! I'm getting the angled cam sensor tomorrow and hoping it clears it up.
Old Nov 6, 2017 | 10:49 PM
cleric670's Avatar
BANNED!!!
Double check that it's the intake one but I'm almost 100% sure that's the one.
Old Nov 7, 2017 | 07:25 AM
Blue Dream's Avatar
I drove ttrank's car solo
Cleric is right, it's the bank 2 sensor one (driver's side) and the angled one. If you can wait order an OEM from Amazon, they're significantly cheaper than going to the Infiniti or Nissan dealerships for them. I got the bank one sensor for almost half of what the Infiniti dealer here wanted for it.
Old Nov 15, 2017 | 08:57 PM
G35stephen's Avatar
So far so good on the cam sensor code, the bank 2 O2 code came back on so ill replace that sensor next.
Thank you both!
