How to empty coolant tank reservoir
Old Nov 19, 2017 | 05:49 PM
Salim Amrani's Avatar
Hi,
I was driving at night and the coolant was very low, the only coolant I've found on my trunk was red (purchased by mistake) so I've put some on the coolant tank reservoir.
I have later removed red coolant from radiator (by disconnecting hose) and flushed with water. I still have red coolant on the reservoir tank, I don't see hoses connected to that. How can I empty that reservoir tank ?
Thank you
Old Nov 19, 2017 | 06:11 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The reservoir has a single screw holding it down then you lift it straight up and it pops right out. You don't even have to disconnect the hose there is plenty of slack to pour out the coolant into another container.
Old Nov 20, 2017 | 11:31 AM
Thanks
