New Muffler
Old Mar 11, 2018 | 05:11 PM
kumaylz's Avatar
New Muffler
Looking for a new muffler on my 2005 G35x Sedan. I don't wanna go back to stock, what are your guys' recommendations? And whats the muffler inlet diameter?
Old Mar 14, 2018 | 07:45 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
What do you want? More sound? More performance (although without doing a full catback you won't get much), something that lasts longer?
Old Mar 15, 2018 | 03:26 PM
MooseLucifer's Avatar
5 Year Member
blk
I have a 'RS Type' muffler that was welded up to fit any 03-06 sedan. I traded my stock muffler for it.. and immediately went out a bought a used stock muffler to re-install. It sounded great, but from 2500-3100 rpm it droned so bad my jaw started to hurt from clenching my teeth on my 20 minute commute every morning.
Moral of the story - buy a muffler that is designed for the G.
PS - the muffler is available in the FS section haha, but I wouldn't recommend it with stock exhaust.
Old Mar 15, 2018 | 07:20 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I had a Tanabe Medalion exhaust but the drone, especially at 2500 rpm (70 mph in 6th gear) was pretty awful. A bit boomy sounding at part throttle acceleration too. First changed the muffler to a Dynomax Super Turbo muffler which definitely helped. Then swapped out the resonator with a Vibrant Ultra Quiet resonator. So still have the Tanabe pipes which are larger than stock but a better sounding resonator and muffler. So even going with a catback, and one that is otherwise reasonably quiet, just doesn't have the research an OEM system can have to eliminate objectionable drone or rasp.
The Dynomax Super Turbo muffler will fit in the OEM location (side entrance, center exit), probably 2.5" diameter will work. Doubt you'll see any performance gain because its so far back in the exhaust and the muffler really isn't a big restriction but you won't have any drone or rasp issues and you will get a bit more volume.
Old Mar 16, 2018 | 04:09 AM
Blue Dream's Avatar
I drove ttrank's car solo
There's a Magnaflow muffler for the sedan 05-06 that a number of members here have used and really liked it. I forget the part number though a search of the forum might find it.
waijai
Intake & Exhaust
Feb 20, 2006 11:02 AM
G-Pimp
Feb 19, 2005 07:34 PM
