Hey bros, Is it common that g35 coupe make rattling noise ?
Old Oct 5, 2018 | 08:47 PM
kent cuzco's Avatar
Old Oct 5, 2018 | 08:49 PM
cswlightning's Avatar
timing chain rattle? It's not common but it happens and means you have to eventually replace your timing chain before it snaps and nukes your engine.
Old Oct 5, 2018 | 09:32 PM
kent cuzco's Avatar
Ratting noise
so when I press the clutch and go to 1st -6th gear I don’t hear the ratting noise.. I only hear it when the car is nice and warmed up and don’t press the clutch . What might be causing the Rattling noise??
Old Oct 5, 2018 | 09:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
When you say "don't press the clutch" you mean in neutral with the clutch disengaged? If so it's probably a worn out clutch that's going to be getting replaced soon, or someone replaced it with a lightweight flywheel and you're hearing chatter.
Old Oct 5, 2018 | 10:27 PM
kent cuzco's Avatar
Thank you bros
Yes yes when it’s in neutral and thank bro will do
Old Oct 5, 2018 | 10:29 PM
cleric670's Avatar
BANNED!!!
Howany miles are on the engine? If you're in the 125k range or so there's a pretty fair chance it's on the original clutch that's showing signs of age.
Old Oct 5, 2018 | 10:31 PM
kent cuzco's Avatar
Bro
so it might be my clutch and flywheel .. do you recommend any clutch and flywheel to get , i wanna drift with my car
Old Oct 5, 2018 | 10:33 PM
kent cuzco's Avatar
99,435 miles the previous owner said he only changed the flywheel and I just started to learn how drive Manuel (3 month) ..
Old Oct 5, 2018 | 11:30 PM
cleric670's Avatar
BANNED!!!
If you could find out what flywheel he used that would help, anything that's NOT a dual mass flywheel will chatter, the lighter the weight the more it chatters.
Old Oct 7, 2018 | 08:58 AM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Maybe, maybe not. Depends on the previous owner(s). Currently at 168k on the original clutch. 2nd owner, original owner was an adult, lived near a freeway for his commute and apparently didn't beat on the car. I've maybe sidestepped the clutch off the line at around 1500-2000 rpm a handful of times in the 2+ years I've owned my car. May chirp the 1-2 shift once a month if that. Don't sit at the light with the clutch pushed in the whole time.
As far as the OP's issue, if the original clutch/flywheel were replaced, a lighter flywheel can chatter. Or possibly if original the throwout bearing is going bad.
cpufreak3
Mar 2, 2022 03:35 PM
kent cuzco
Aug 22, 2018 05:32 PM
TNight
Jan 27, 2017 07:41 PM
RADIOGUY21
Jan 3, 2015 09:16 AM
