Infiniti G35 ticking when revving/accelerating
Old Nov 29, 2018 | 05:49 PM
gphartnett's Avatar
2003 Infiniti G35 MT Sedan RWD
Question Infiniti G35 ticking when revving/accelerating
So I have a 2003 G35 sedan MT a few months ago. Engine started making ticking noise at 2500-4000rpm. The ticking is only from one cylinder (cylinder 6). Did motor flush and oil change with Mobil 1 super synthetic 10w-30 oil and added Lucas oil stabilizer. I only use 93 octane fuel from shell or mobil gas stations. Nothing is helping and I can’t find a direct answer online. There is NO loss of power since noise started.
Every few weeks it will have low idle and stuttering when revving/accelerating, but it goes away after a couple seconds.
Is it bad valves? Timing? Please help!
I have a video of the noise on youtube, here's the link:
Old Nov 29, 2018 | 07:52 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
First thing I'd check is to be sure the plug is fully tightened, sounds almost like an exhaust leak. Fuel injectors can tick, so can valves out of adjustment.
Old Nov 29, 2018 | 07:57 PM
gphartnett's Avatar
My exhaust ends after the Y pipe that’s why it’s noisy.. Which plug do you mean?
Old Nov 29, 2018 | 07:59 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
#6 cylinder. Not sure if it is common with the VQ35 but notoriously common with Honda J series V6 engine for spark plugs to back out and make a ticking sound.
Old Nov 29, 2018 | 08:04 PM
gphartnett's Avatar
I’ll take a look at the plugs tonight! I’ll let you know soon. Thank you!
ara777
Aug 15, 2015 09:59 PM
astaan
Oct 9, 2005 11:37 PM
aerisolphaln
May 26, 2005 09:01 PM
Basheer
Mar 24, 2005 05:15 PM
