Car not starting, please any help is needed
Old Dec 12, 2018 | 03:38 AM
Ryanwalltho's Avatar
G35
so my G used to run fine, then I hadn’t started it for around 6-8 months. When I recently tried to start it again it makes this noise (refer to video). Could anyone help as to what the problem may be? It’s an 03 coupe.
Old Dec 12, 2018 | 04:45 AM
Scorpi0's Avatar
Cant play your video.
But Im assuming the noise is a very fast continuous tick sound. That usually means your battery is dead. Jump start it from another car or get a new battery.
Old Dec 12, 2018 | 07:38 AM
telcoman's Avatar
Veteran: Army
Replace the battery
Telcoman
Old Dec 12, 2018 | 10:45 AM
coffeysm's Avatar
The video was kind of short, but I didn't see your RPM needle move when you were cranking. Does it move when you crank the engine? It could be your crank sensor if that's the case (not a full proof test though).
Try spraying some brake/carb cleaner or starting fluid in the intake close to the throttle body. If it starts then you have a fuel delivery issue if still doesn't you want to see if you have spark. If you don't have spark then I'd look at your cam/crank sensors too (as long as the wiring looks good).
Check your battery voltage with a multimeter (~12.6 I think you are looking for) and try tapping the starter with a mallet or something while someone cranks. That noise when you were cranking didn't sound normal to me (so, it could be your starter).
Old Dec 12, 2018 | 11:10 AM
FreshLikeAG's Avatar
Kinda sounds like the starter is spinning but not engaging. Is your engine even cranking?
Old Dec 12, 2018 | 11:56 AM
coffeysm's Avatar
That's what I thought too and I couldn't really tell from the video. That's what happened with my starter though the bendix starting flopping around and occasionally it would catch and start the car up. Luckily, it's an easy swap on the G35; I think on the later models it's an all day event.
trini35
Jul 5, 2025 04:13 PM
KARMA_G35
Oct 13, 2017 11:45 AM
tnguyen
Aug 17, 2014 12:33 PM
BolivianFuego
Feb 13, 2013 12:01 AM
