Updated 2005 Intake Manifold Collector
Old Mar 8, 2005 | 08:59 AM
neffster's Avatar
Originally Posted by dklau33
Well that's peak torque. Peak numbers don't mean that much compared to the entire curve.
Yeah I know that. Man, you stole my thunder.
Old Mar 8, 2005 | 09:06 AM
RBull's Avatar
Rated M
Same is true with horsepower of course.
Old Mar 8, 2005 | 11:42 AM
dklau33's Avatar
Originally Posted by n1cK
here's something from my350z.com that may shed some light on the subject.
n1cK
I already posted that link above!
Old Mar 8, 2005 | 12:01 PM
DaveB's Avatar
Originally Posted by pdjafari
DaveB,
The cars went from 280HP to 298HP...as far as I recall while I was 'researching' before purchasing the 03-04 5AT and 6MT both were rated at 280HP....
Yeah I know, but Nissan did some funny math with the G/Z cars. The 280hp coupe puts out within a couple whp/wtq as the Z. About the only thing different is the intake pipe on the Z is slightly less restrictive.
The 03/04 260hp G sedan makes within 5whp/wtq as the 03/04 coupe. Which leads many of us to believe the Z/G coupe/G sedan are all using the same motor. The sedans make a little less power due to a slightly more restrictive intake/exhaust and spinning a 1' longer driveshaft. Tranny to tranny, the numbers are much closer than the "rated" numbers would suggest. The 03/04 sedans are putting down closer to 270-275hp, not 260hp. The 05 sedans probably have a retuned ECU, but I'd venture to say that's only good for 5-10hp over the 03/04. Somehow the 05 sedans gained 60-70lbs in the update too which doesn't make much sense.
As for the 05 298hp-300hp 6 speed Z/Gs, well that's a largely changed motor. Different cams, updated valvetrain, different block, rods, and timing changes.
Old Mar 8, 2005 | 12:05 PM
DaveB's Avatar
Jason@PerformanceNissan has posted his findings of the difference between the old and new lower plenums. Here's a pic.
Go to the my350z link posted above to find out more. You can definitely see the design change as the new lower plenum has more open area before the runners.
Hmmm, there are some differences for sure. For $207, it may be worth a try. It's hard to tell what kind of gains could be had, but it appears there is more air volume ahead of the runner.
dklau33's Avatar
And don't forget the new lower plenum.
Old Mar 8, 2005 | 12:24 PM
dklau33's Avatar
Here's my half *** MS paint attempt at highlighting the differences between the old and new lower plenum. Definitely more area before the runners.
Old Mar 8, 2005 | 01:48 PM
DaveB's Avatar
Doh!!!!!!!
I've been following the 350Z post and it seems interesting to say the least. A guy did a baseline yesterday and will be redynoing Wednesd/Thursday with the new plenum. I'm curious to see the differences. If it works (~8-10whp), I'd be more inclined to get this first instead of the spacer. It's hard to tell if the shorter runners will affect low rpm power or not because these intake manifolds behave so much differently than your typical fixed and variable plane intake manifold.
Old Mar 8, 2005 | 02:15 PM
njsfastestg's Avatar
G SQUAD
please keep us posted on the b4 and after dynos because i mm lookin into buying it and the aps plenum.
thanks guys
Old Mar 8, 2005 | 04:35 PM
mbq62's Avatar
So is there a final census on what kind of gains you may get with this?
Old Mar 8, 2005 | 04:47 PM
pdjafari's Avatar
5-7+ HP and id be in if price was 250-400, anything more than that...and i prob. WONT
dklau33's Avatar
Go to the my350z thread that has been linked twice in this thread. Go read that thread and keep up to date with it. So far, a baseline dyno has been done on the test car. Then another dyno will be done this Wed/Thur with the new lower plenum. Results will be posted over there.
Old Mar 8, 2005 | 04:48 PM
pdjafari's Avatar
my350z site is down btw!!
Old Mar 8, 2005 | 04:56 PM
G35Five_O's Avatar
You can pre-order at G34 Everything for 199.99. Performancenissanparts might beat that price. The part is being researched now to see if there is any gains. Hopefully there is and I want to see if the spacer will work with this product.
Just wait and see....
Old Mar 8, 2005 | 05:28 PM
  #30
booger's Avatar
Like what was stated earlier , There are alot of parts that make the 05 have more power . But IMO the new lower plenum is one of the reasons it has less trq. From what I understand ...longer runners...more trq. ....shorter runners....less trq .
The runners were probably shortened to help with the air flow to the front cylinders
