03 G35 Coupe
Old Apr 15, 2019 | 08:15 PM
Charris926's Avatar
G35 Coupe
03 G35 Coupe
2003 G35 Coupe (automatic) -132k miles
No major problems before this. Burns oil moderately quick, but I regularly check and top off with regular synthetic oil changes. Store during the winter. I noticed this noise about a month and a half ago, but only on cold mornings and would only last about a second. If the radio was on or you weren’t paying attention, you wouldn’t even notice. For a couple weeks it didn’t make the noise, and I initially thought it was because it was warmer. The car sat for a week without starting because I was away. Once I started it again, the noise started and never stopped. It gets a little louder while accelerating, but generally the same as idle. As I said, it’s constant now. I haven’t driven it since the day it became constant, and only took it around the block and turned back home because I didn’t want to damage anything further. During the drive, the transmission seemed fine. Oil level was a little low but nothing alarming and I noticed some built up oil residue below the engine. I’ve attached a video because I haven’t found a post similar to my problem. I’m going to have it towed to a shop
tomorrow, but want to have an idea of the problem before the car gets there because I am not mechanically knowledgeable.
Note: Belt Tensioner/Pulley replaced about 10k miles ago
Link to video:
File Type: mov
Old Apr 15, 2019 | 08:38 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Upload the video to YouTube and post a link. The attached video is invalid
Old Apr 15, 2019 | 09:39 PM
Charris926's Avatar
G35 Coupe
linked
Old Apr 17, 2019 | 10:26 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Sounds like the idler pulley on my Accord when it went bad.
Old Apr 17, 2019 | 10:59 PM
cleric670's Avatar
BANNED!!!
Take the belts off and spin everything by hand, it will be super obvious which one is about to break off.
There are TWO tensioners, one for each belt, AND an idler pulley on the primary belt all 3 are common wear items.
aswilson13
Dec 12, 2009 05:51 PM
djmonsta
Mar 18, 2009 07:53 PM
fluffy
Oct 27, 2008 01:35 AM
couchpotato300
Jun 20, 2008 11:14 AM
EricIsKlumzyee
Apr 29, 2005 02:23 AM
