Negative fuel trim? (-20)?
Old Apr 18, 2019 | 09:53 PM
Jbutku4's Avatar
Hello,
After getting the gizmo to diagnose a CEL, I have been fascinated by it, and maybe overthinking it? However, I noticed that my Long term Fuel Trim on both banks is around -20. Is it not supposed to be around 0? I have no CEL, but I will list 2 things that may be affecting my fuel trim?:
  1. Exhaust leak at the Flex joints on Y pipe
  2. My car once stalled after flooring it (Once I came to the stop the car stalled) and P0340 showed as pending, but no CEL, hasn't happened again.
So, is the negative fuel trim OK? Or is there something to look for?
2003 Infiniti G35 Coupe
140,000 Miles
Mods:
Stillen Z Tube
Motordyne Plenum Spacer
Old Apr 18, 2019 | 11:23 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
ECM subtracting fuel usually means leaking injectors or oversized injectors used with factory ECM fuel maps.
Old Apr 18, 2019 | 11:25 PM
cleric670's Avatar
BANNED!!!
Technically it could also be a very weak ignition not fully igniting the fuel load, I'd pull the plugs and inspect the gap, replace as needed. I would also change out that cam sensor before it completely fails and leaves you stuck on the side of the road.
Old Apr 19, 2019 | 12:19 AM
Jbutku4's Avatar
Will replace cam sensor as preventative maintenance as we are going to Texas from Illinois soon.
Any way to identify if my injectors are not OEM? Don't have previous owners contact info anymore.
Old Apr 19, 2019 | 02:42 PM
cswlightning's Avatar
You can take the intake manifold off and look :P
Old Apr 24, 2019 | 12:16 AM
scumbagsleeper's Avatar
1990 Mustang GT - 351W Lightning bored/stroked 383CI TFS heads 78mm Turbonetics huricane
What is the fuel trim at partial throttle with load (Like 30% throttle going uphill)?
iTzTeddy
Apr 13, 2016 06:18 PM
350z006
Engine - Intake/Fuel
Jun 8, 2012 01:18 PM
BeerViper
DFW G35 Owners Club
Nov 12, 2010 01:28 PM
exagorazo
Jul 3, 2004 07:48 PM
