G35 spark plug replacement
Old Jan 11, 2020 | 12:43 PM
Spanrd's Avatar
So I'm replacing both valve cover gaskets, plenum gasket, and the spark plugs plus coils. Been looking for spark plug wires, and only thing I found online is that they use coil packs ? Which I dont understand. I'm thinking I should replace the wires, but cant find any
Old Jan 11, 2020 | 04:24 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
There are no separate wires on this motor, the coil pack sits directly over the spark plug and the bottom of the coil pack has a well shaft boot that fits directly onto the plug end. Don't bother replacing coils if they're working, it's not exactly a wearable item. Inspect them when you do the plug and if you see any scorching on the well shaft boot, or corrosion on the contact spring inside it, or blistering of the epoxy resin encapsulation (black shiny **** on the top) or corrosion on the pins for the harness, then replace JUST those coil packs.
Homero Perez
Jan 5, 2020 07:42 AM
TiIngot
Aug 12, 2019 07:41 PM
Sarah Kibler
Jul 10, 2018 10:31 AM
Tyron
May 2, 2016 10:03 AM
DaveB
31
Jun 16, 2007 04:23 PM
