G35 Sedan, high compression,Poncams,exhaust,porting to heads and intake,lowered on coilovers,tuned
Help identifying gaskets.
I got a set of remanufactured heads recently. Was going to install them and noticed i didn't have everything.
bellow is the old heads that looks like it has a couple small crushed gaskets(black) that seem to go to the timing cover. Could you possibly tell me what they are called or a part number? Trying to get this back together asap so i can make it to the track early april.
This forum seems dead anymore. So anyone that comes across this searching. They are the "small timing cover o-rings) you need 6 all together when doing a rebuild or headgasket. I found mine on Z1 thanks to them for answering back. Mahle also makes a full timing gasket kit that includes every o ring for the front and rear covers.
